Suspension & Brakes Theory, alignment, spring rates....
Degrees of Adjustment for SPC/Wicked Tuning/Blox Adjustable Toe Links?????
Old Jan 23, 2008 | 10:42 PM
onecleanDA's Avatar
Default Degrees of Adjustment for SPC/Wicked Tuning/Blox Adjustable Toe Links?????
Does anybody know from alignment experience or off the top of their head the degrees of adjustment for SPC/Wicked Tuning/Blox adjustable toe links????? None of the websites list them....
Old Jan 28, 2008 | 03:20 AM
onecleanDA's Avatar
Default Re: Degrees of Adjustment for SPC/Wicked Tuning/Blox Adjustable Toe Links????? (onecleanDA)
nobody eh?
Old Jan 28, 2008 | 04:27 PM
Targa250R's Avatar
be professional
Why do you think that you need these?
Old Jan 28, 2008 | 08:31 PM
slammed_93_hatch's Avatar
Default Re: Degrees of Adjustment for SPC/Wicked Tuning/Blox Adjustable Toe Links????? (Targa250R)
if you can't get it in spec within the stock adjustment range then something is bent.
Fix the problem, don't use a band aid.
Old Jan 28, 2008 | 10:40 PM
onecleanDA's Avatar
Default Re: Degrees of Adjustment for SPC/Wicked Tuning/Blox Adjustable Toe Links????? (slammed_93_hatch)
The reason why I ask is when using any aftermarket lower control arms on a DA, the toe is thrown off significantly, due to the fact that the EG/DC lower control arms are shorter than the DA arms.
Old Jan 29, 2008 | 03:19 AM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onecleanDA &raquo;</TD></TR><TR><TD CLASS="quote">The reason why I ask is when using any aftermarket lower control arms on a DA, the toe is thrown off significantly, due to the fact that the EG/DC lower control arms are shorter than the DA arms. </TD></TR></TABLE>
"Doctor, it hurts when I do this!"
"Don't do that."
HFpower
May 22, 2008 06:05 PM
allmotorhawaii
Jan 11, 2008 11:07 PM
matt1982
Mar 17, 2007 09:45 AM
