Noob Question
New to Honda-Tech (used to v-bulletin forum format)... I tried searching and sifted through the FAQs... but no luck
Can someone tell me what the % that appears under each members post count denotes? Is that their trader rating?
Thanks!
.Can someone tell me what the % that appears under each members post count denotes? Is that their trader rating?
Thanks!
The % rating is how 'in' with the moderators you are. The more you expletive up and **** them off, the more percentage gets taken away.
Mods also look at user ratings when determining if they are a problem, so the lower your points, the more likely you are to lose MORE points, or be banned.
As you can see, I have 96%, which means I'm kind of a jerk.
