Q about ARC intake box.
FYI, I have seen several EK versions of the ARC box used with the stock intake tube; however, to get the best result (i.e., torque boost around VTEC, and best throttle response), you should use it in conjunction with the intake chamber
I'm sure Ben@AJR would concur.
That I dunno; I would guess $$$.
Why not buy thru Jacob(?) @ ART?
If not, Garage R in Singapore should be able to get it for you, ask for Lester Wong
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
does the ARC intake box work with the stock rubber intake pipe? or do you have to buy the ARC intake chamber? cheers
i'm not sold on the intake chamber, although i do have the arc ek box in my old 94 civic hatch. with some modding, it fit perfect with a stock itr intake hose. someone gimme a before and after dyno sheet with the chamber and without, then maybe it'll be worth the extra modding to get it in, but for now the stock rubber hose works for me.....
teejlc
Jun 29, 2007 08:40 AM
