Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Is this common ? Blown motor on a new civic
Old Jan 23, 2008 | 07:11 PM
Kavehman's Avatar
Default Is this common ? Blown motor on a new civic
This car seems pretty much stock, and honda australia is refusing to warranty it ?
Seems about par with honda service worldwide.
http://www.ozhonda.com/forum/s...10111
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bob san;1510111 &raquo;</TD></TR><TR><TD CLASS="quote">Today i was driving to the glen with a friend to get somethin to eat. started the car up seemed fine just like any other day. turned out of my street and onto the main road. was doin 60km on a 80km at about 3000rpm then suddenlty boom.
i then stopped in a service lane to see what had happened. the engine block had blown a hole the size of a thumb and oil was leaking everywhere. called the mechinc to check it out and he said its most likely an internal engine problem. this had happen literally 2mins away from my house and i was driving very carefully knowing that the engine was still cold.
i have always serviced this car ontime and it has given my no trouble since i picked it up in april 06. my car is not stock it has p1s, exhuast, lowered, cai etc. but there is no way in hell these kinds of mods will lead to a car blowing up a bottom end. i mean anyone with knowledge on cars will know that it is pretty hard to physically blow a hole in a solid alluminum block.
the last service i didn't go through honda and had done it through a long time trusted mechanic friend. should i call up honda and demand them to fix my car or call insurance and have the car wrote off? any help is much appreciated.</TD></TR></TABLE>
Old Jan 23, 2008 | 07:17 PM
rockybalboa11's Avatar
Default Re: Is this common ? Blown motor on a new civic (Kavehman)
is this common? i'd imagine not.
Old Jan 23, 2008 | 08:58 PM
TheMuffinMan's Avatar
He knows where you live!
Uhh, assuming you haven't taken it to Honda yet.
Put it to STOCK and THEN take it in
Old Jan 23, 2008 | 09:54 PM
pd0019's Avatar
Default Re: (TheMuffinMan)
common?...definitely not.
but i have read about a couple people having this happen to. probably between 8-10 people i think, but thats too many even for how many civics honda puts out.
Old Jan 24, 2008 | 03:05 AM
RICO_'s Avatar
NO MERCY!
Default Re: (pd0019)
Honda techs should be able to get into the ECU and determine whether the car was over-revved or not. Blowing a hole like that clean through a block is extremely hard to do. And at only 3K rpm it shouldn't happen at all. I would tell him to plead my case with Honda and have them PROVE that the car was intentionally abused.....if they can't prove it then they have to honor the warranty.
The presence of aftermarket parts alone is NOT grounds for denying a warranty claim.
Old Jan 24, 2008 | 04:57 AM
hondamanforlife's Avatar
like RICO said! here in the states the laws may be diffrent but the dealer cant void your warenty becuase of bolt on's. Im not sure about AUST is it the same there? get honda to buy that **** back and go get a Holden comador SS I wish we had them here! good luck!
Old Jan 24, 2008 | 06:41 AM
yuning83's Avatar
Default Re: Is this common ? Blown motor on a new civic (hondamanforlife)
He has a CAI, they can always blame it on that.
Old Jan 24, 2008 | 09:07 AM
chiggin's Avatar
Default Re: Is this common ? Blown motor on a new civic (yuning83)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yuning83 &raquo;</TD></TR><TR><TD CLASS="quote">He has a CAI, they can always blame it on that. </TD></TR></TABLE>
Not sure how a CAI could blow a hole in the block.
I wonder if a freeze plug could have some how popped out?
Old Jan 24, 2008 | 11:26 AM
JchanFTW's Avatar
You guys forget that he lives in Australia, it's a completely different country with different sets of laws. I'm not sure if the MM warranty act applies.
Honda should cover it, I don't see why they wouldn't based on what you've told us.
Old Jan 24, 2008 | 11:31 AM
HA0LEFIED's Avatar
even if there is a safety if the car isnt warm enough..
Old Jan 24, 2008 | 05:29 PM
Hondacivic90ed's Avatar
Granted the aftermarket parts may have contributed to the engine blowing up, defects are definately not out of the question. Today at our dealership we had an '07 civic LX with a grenaded 5spd transmission. The ring gear on the differential lost chunks of about 10 teeth. Looking closely at the first tooth of which was missing the most amount of metal you could see a half of a void in the metal, a bubble in the casting of the ring gear. Originally Honda wanted us to rebuild the transmission because of lack of available new transmissions on such a new car, but after the extensive damage was shown to Honda involving no only the ring gear but also the casings and mainshaft teeth, Honda warrantied a new transmission.
Old Jan 24, 2008 | 08:56 PM
BigHec's Avatar
Did you run it through a deep puddle?
Old Jan 24, 2008 | 09:05 PM
lostjap89's Avatar
Default Re: (BigHec)
i read through the whole thread and honda end up not covering it on the basis that it was not honda genuine oil so therefore not covered.
Old Jan 25, 2008 | 02:53 AM
RICO_'s Avatar
NO MERCY!
Default Re: (lostjap89)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lostjap89 &raquo;</TD></TR><TR><TD CLASS="quote">i read through the whole thread and honda end up not covering it on the basis that it was not honda genuine oil so therefore not covered.</TD></TR></TABLE>
WRONG. Honda can't deny warranty because you don't use THEIR oil. If so places like Jiffy Lube and any other place that does oil changes wouldn't exist.
As long as the correct weight of oil is used then it will still be covered.
Old Jan 25, 2008 | 02:37 PM
memphisfuk's Avatar
Default Re: (RICO_)
true that... i have a buddy of mine here in memphis with an 07 si and his motor blew up on him and they replaced it and also just a couple of months ago in Honda Tuning there was an article about a new civic that had already had to have a new engine installed. I put royal purple in my 07 and the dealer said that they will put it in if i just pay for the labor.....
Old Jan 25, 2008 | 03:15 PM
Default Re: (memphisfuk)
We use quaker state bulk oil for 99% of our oil changes unless otherwise specified by the customer then Mobil 1 or Amsoil can be chosen. This is at a Honda dealership.
Old Jan 25, 2008 | 03:29 PM
lostjap89's Avatar
Default Re: (RICO_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BOb san_ &raquo;</TD></TR><TR><TD CLASS="quote">
bad news guys...
just got off the phone with the operations manager. accoroding to 'his' understanding it will not be covoered by honda australia as the car has been subjected to 'driver abuse'. he also claimed i had overfilled the car with non genuie oil (ok, so how does that blow up a bottom end?) he gave me no actul explanation of how the engine actully came to blowing up the bottom end which i find is quite atonishing.
i demanded that i have a copy of the report honda australia gave him. to my suprise he said 'i have to get it from honda australia urself'. no i want the EXTACT report honda australia gave him. same reply.
i am going to go down to the dealership now and photograph every single part of the car (espcially the engine).</TD></TR></TABLE>
I miss read it just a bit but it was from driver abuse he just said on top of it sorry about that
Old Jan 25, 2008 | 05:41 PM
underbelly's Avatar
Default Re: (RICO_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">The presence of aftermarket parts alone is NOT grounds for denying a warranty claim.</TD></TR></TABLE>
Kinda like installing a amp for your factory speakers and blowing them out, then crying you want them to replace the speakers for free........
If you have a intake/header/ext, and you blow your motor they will turn you down everytime... And guess what, there is nothing you can do about it...
Old Jan 25, 2008 | 06:05 PM
Default Re: (underbelly)
sue!! that's what you can do about it! my dealer said I can bolt on just about anything and it will not void my warranty. unless it's forced air ,ECU, or internal motor work. I/H/E will not void anything! dealer's want people to think that you can void your warranty with mod's so they can charge you for every little thing to make money. warranty work does not pay as much as a customer would pay. it just tactics to make more money!
Old Jan 25, 2008 | 06:12 PM
underbelly's Avatar
Default Re: (hondamanforlife)
And whats your dealers name?
Old Jan 26, 2008 | 06:48 PM
wich one? drugs or car? norris honda of dundalk MD/also Browns honda of glen burnie MD. I cant give you the other one he/she might get mad at me! just kidding!!
Old Jan 26, 2008 | 06:57 PM
RICO_'s Avatar
NO MERCY!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by underbelly &raquo;</TD></TR><TR><TD CLASS="quote">
First....any person that puts any decent aftermarket amp on factory speakers deserves to be slapped in the face, kicked in the left nut, and titty-twisted till their nipples fall off. Most factory speakers are basically made out of paper and aren't built for the level of performance as most aftermarket ones. Therefore they could never handle that amount of power to support an aftermarket amp short of maybe a dinky little 25W X 4 RMS.
Second.....if you blow your motor you will most likely be turned down regardless of whether you have aftermarket parts or not. Over-revving can happen just as easily with OR without mods. It's mainly common in mis-shifting...not the aftermarket parts by themselves.
If however your tranny decides to go out and you have an intake system on your car, they would have to prove that the intake contributed to the transmission going out....which is highly unlikely.
Old Jan 26, 2008 | 08:18 PM
Chiovnidca's Avatar
What year and model was it? How many miles?
Old Jan 27, 2008 | 05:07 AM
Kidnkorner's Avatar
Looks like a thrown engine rod. Drop in oil pressure&lt;spun rod bearing&lt;thrown rod. It takes some high rpm to throw a rod to cause damage like that. I did it before on purpose I had to hold the throttle bouncing off a 6600 rpm rev limit (non honda) for 2:43 seconds.
I'd check to see if there is some law like we have in the states called the magnusson moss warranty act. Here in the states dealers/manufacturers must prove the the part(s) caused or contributed to the cause for which a warranty claim is sought.
I know it's not much help to you but check this link out.
http://www.dummies.com/WileyCD....html
Perhaps the person could seek legal council on automotive issues.
invision
Aug 21, 2008 05:46 PM
jay2kidd
104
Dec 13, 2006 12:14 PM
speedracer33
Mar 9, 2006 06:23 PM
TRAG
Mar 9, 2006 12:02 PM
Flux
Jan 28, 2005 06:07 PM
