'98 Civic - Charcoal canister plug?
Old Jan 23, 2008 | 06:10 PM
dubzz24's Avatar
Default '98 Civic - Charcoal canister plug?
Alright guys, bought this car with a spun rod bearing last week. It's a '98 Si coupe (same as your guys EX coupe). Picked up and dropped in a motor from a '98 Acura 1.6EL (d16y8, just like my stock motor). The motor came with wiring harness so I just used the harness that came with the motor. When I was finishing up the install, I realized that the harness that came with the new motor is missing the plug for the charcoal (EVAP) canister.
I really don't want to swap harnesses, so I was just going to cut the plug off the stock harness and wire it up. Only thing is I have no idea where it needs to be wired to. I tried looking through a service manual and I couldn't find which ECU pins it would go to...
Any help would be appreciated!
Old Jan 24, 2008 | 09:41 AM
dubzz24's Avatar
Default Re: '98 Civic - Charcoal canister plug? (dubzz24)
Bump!
Old Jan 24, 2008 | 09:44 AM
BryanM.'s Avatar
Resident Gearhead
iNo comprende!
Are you talking about the purge solenoid plug?
Old Jan 24, 2008 | 01:48 PM
dubzz24's Avatar
Default Re: '98 Civic - Charcoal canister plug? (mcvtec)
I tried searching google images and couldn't find any good pics that show what I'm talking about... But, the charcoal/EVAP canister that's mounted near the fuel filter, on my EK there's one sensor plug on the canister that the harness from the '98 EL doesn't have.
I can try to take a picture if you still don't know what I'm talking about...
Old Jan 24, 2008 | 02:02 PM
HondaPartsHero's Avatar
Technical Hero
http://technet.ff-squad.com/wiring.obd2a.htm
if its the EVAP purge it looks like A15 is one of the wires, not sure if the OBD2 is a switched power or ground for the other wire
Old Jan 24, 2008 | 02:07 PM
dubzz24's Avatar
Default Re: '98 Civic - Charcoal canister plug? (HondaPartsHero)
Isn't the evap solenoid on the IM of a y8?
Old Jan 25, 2008 | 07:44 AM
BryanM.'s Avatar
Resident Gearhead
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dubzz24 &raquo;</TD></TR><TR><TD CLASS="quote">Isn't the evap solenoid on the IM of a y8?</TD></TR></TABLE>
Yeah, that's what I was thinking - Y7s and Y8s have the EVAP PS on the IM last time I checked...never seen a plug on the actual charcoal caniser. My '96 Y7 doesn't have a plug there...maybe it's a '98-'00 thing. Weird.
Is it throwing a CEL because it's not hooked up?
Old Jan 25, 2008 | 10:44 AM
dubzz24's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mcvtec &raquo;</TD></TR><TR><TD CLASS="quote">
Is it throwing a CEL because it's not hooked up?</TD></TR></TABLE>
I've never before seen the plug on the charcoal canister either, but I've always dealt with EF / EG / DA's... I'm waiting on a balljoint so I can finish everything up so I'm not too sure about the CEL yet. I'll be finishing it up on Sunday so I'll post up the results when I get them
Old Jan 25, 2008 | 11:43 AM
speedooo's Avatar
its an ex/d16y8 sensor. the charcoal canisters are different
bungdogjb
Dec 8, 2015 05:27 AM
donvito#1
Mar 14, 2008 09:31 AM
r.f.b
Jun 27, 2007 08:10 AM
japspec
Sep 9, 2005 07:03 PM
japspec
Sep 9, 2005 08:06 AM
