Turbo S with and without HG.. have some questions
Something I have been wondering....
For the sake of argument lets say I have a stock motor AP1 and have the Full Race kit ready for install.....
Now before I install a question... If I leave stock compression and run say, 8psi. I should make roughly 330-350whp. (just a guess) Now to get that same whp with a 3mm head gasket I would need about 12-15psi. (just another guess) So if this is the case what benefit would having a HG for reliability when you could get the same HP with less boost? Or am I just smoking crack?
If one of you boost junkies could explain this too me I would appreciate it a ton.
Full Race
ive seen s2000s with all stock motors putting down a little over 400WHP
If you baby it im sure it will be fine if you dont drive the **** out of it.
the full race kit is a lot tho you should look into rev hard I would only go with the full race unless your built
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaKyle »</TD></TR><TR><TD CLASS="quote">Full Race
the full race kit is a lot tho you should look into rev hard I would only go with the full race unless your built </TD></TR></TABLE>
The setup was all hypothetical, I am just concerned with boost with HG vs. boost without HG.... I am well aware of what the S is capable of.
get a 2MM COMETIC
It Reduces overall compression down to 9.83:1
Here is a link for one
http://automotivespeed.com/pro...d=133
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaKyle »</TD></TR><TR><TD CLASS="quote">get a 2MM COMETIC
http://automotivespeed.com/pro...d=133</TD></TR></TABLE>
Again dude... You fail to see the question. I want to know the true benefit of a HG vs. not having one. Reading > you my friend.
It Reduces overall compression down to 9.83:1 lol
Boost doesn't like high comp....and this is stronger then stock all the boost is gonna brake a stock one ......
Here's the deal.
- If you daily drive the car and or are going to drive the car hard. Get the headgasket. (just for piece of mind).
- If you think you're going to want more power in the future, just get the headgasket now, so you can take it up to around 500rwhp without any problems. On stock compression, you're pushing the limits once you hit 380-400 or so mark.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by papa5murf »</TD></TR><TR><TD CLASS="quote">Here's the deal.
- If you think you're going to want more power in the future, just get the headgasket now, so you can take it up to around 500rwhp without any problems. On stock compression, you're pushing the limits once you hit 380-400 or so mark. </TD></TR></TABLE>
Noted...
So am I accurate when I say that you get close to the same HP with less boost stock compression. Than say more boost less compression? Sorry, just having a hard time understanding.
Noted...
What about the stock clutch?</TD></TR></TABLE>
Not a chance man. Hell, even I know that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaKyle »</TD></TR><TR><TD CLASS="quote">just for like 8 pounds of boost ??!?!!?
It wont last man. The stock clutch is not that strong.
</TD></TR></TABLE>It wont last man. The stock clutch is not that strong.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaKyle »</TD></TR><TR><TD CLASS="quote">that really pisses me off ..... its hardly any power
wanna buy an s2000?</TD></TR></TABLE>
LOL.. I would but I already have one.
wanna buy an s2000?</TD></TR></TABLE>LOL.. I would but I already have one.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Agent Zero »</TD></TR><TR><TD CLASS="quote">
Yes
Think about it this way. A Stock S at the flywheel puts out 240hp at the current compression. Now lower that compression on a stock S, you won't be pushing nearly as much power (say for instance 210hp, not fact, just hypothetical number). That means you have to compensate for that extra 30 hp loss by boosting more to achieve the same power. Make sense?
</TD></TR></TABLE>Yes
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaKyle »</TD></TR><TR><TD CLASS="quote">thanx papa!
What about the stock clutch and diff?</TD></TR></TABLE>
Depends on how much power you're putting down. Torque wise. I'm pushing in the area of 400rwhp/300wtq, and I'm using my stock diff. So far so good. As for the clutch, I swapped it out to a Spec Stage 1. People might think it's weak cause it's a stage 1, however, this stage 1 holds up to around 320wtq, which is more than I'm pushing.
I feel it's useless to get a stage 5 clutch that holds 500wtq if you're never going to achieve that number. It's just taking things overboard.
It'll work, but it won't last you too long.
</TD></TR></TABLE>It'll work, but it won't last you too long.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by papa5murf »</TD></TR><TR><TD CLASS="quote"> Make sense?</TD></TR></TABLE>
I think so. So running 8psi and pushing 300whp(stock) and (same motor) running 13psi pushing 300whp(with head gasket) = same reliability?
Again man, sorry for the redundancy I just wanna be really clear on this before I begin my build.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaKyle »</TD></TR><TR><TD CLASS="quote">I just need it to last for the summer and It wont be my DD
So ill just hope it will last 4 months </TD></TR></TABLE>
Well you also have to think about installation. You'll have to remove half of the turbo kit just so you can swap the clutch out later down the road.
Im glad you posted this i was gonna post some asking a couple simpler questions
yeah some thing like that... but you dont wanna go to low with out boost a 3mm on 8 pounds would be bad
</TD></TR></TABLE> yeah some thing like that... but you dont wanna go to low with out boost a 3mm on 8 pounds would be bad
I think so. So running 8psi and pushing 300whp(stock) and (same motor) running 13psi pushing 300whp(with head gasket) = same reliability? </TD></TR></TABLE>
You're on the right track with the numbers. As for reliability, it's debatable. Some say yes, others say no. I'm one that says head gasket will increase reliability. One thing for sure though is that the head gasket will give you more potential in the long run (power wise).
Thanks again man. You have been a great help.
