Noob Koni suspension questions
Old Jan 23, 2008 | 12:25 PM
PuroMotor's Avatar
Default Noob Koni suspension questions
I searched and I mostly get Marketplace results. I posted this in the proper forum but nobody seems to even go on there.
Ok Ive been reading around regarding the Koni yellow and GC suspension setup. I understand this seems to be the more popular setup and there isnt anything negative said about them. Ive been to a few online stores to shop for Koni yellows. I have a 91 CRX Si. On the sites it states that you have to "cut and weld" a part of the Koni shock. Im asuming its the area where the spring or GC coilover sits on but im really not sure. In the forums nobody really talks about welding or cuting anything on the shocks. Could someone please clarify this for me.
My other question is, what are extended top hats? What is their function and are they a must when using the Koni GC setup? Also there are two types of Konis.. The regular yellows and some sort of shortend koni yellow. What is the difference?
thanks for any info.
Old Jan 23, 2008 | 12:33 PM
gourley's Avatar
Default Re: Noob Koni suspension questions (PuroMotor)
The shortend koni yellows are just a shorter version of the orginial knoi yellow.
The piece they are talking about you need to cut/weld is prolly the brake line bracket. IMO I never used them since I never found use for them (Ill prolly get bashed for this, 4 cars later and I still havent had any brake problems).
Old Jan 23, 2008 | 12:37 PM
PuroMotor's Avatar
Are the shorter ones better? I read somewhere that they only handle up 600 lbs for spring rates. What would be the better setup for the CRX ? the regular yellows or the shorter ones? What about the top hats?
Old Jan 23, 2008 | 12:45 PM
gourley's Avatar
Default Re: (PuroMotor)
If you want to be slammed, go with the shorter ones, then get custom spring rates from GC. If your going to DD and want to just be lowered, go with the normal Koni's. Goodluck!
Old Jan 23, 2008 | 01:15 PM
PuroMotor's Avatar
Hey man thanks for taking the time to answer my questions.
travisallenn
Suspension & Brakes
Nov 30, 2006 04:55 PM
94IntegraLs04
Suspension & Brakes
Jun 11, 2006 05:44 PM
