quick Q about the crash washar
can u tell me please , is the engine oil drain plag has the normal washar??? because i was gonna get one to replace after drain engine oil, but the shop says i have to get it from dealar???!!!! i was shoked. can u tell me if i can use a normal washar or not??? thanks n adv.
You can get one from Autozone, Kragen, pep boys etc. They are typically made from aluminum or copper so they will conform and crush to create a seal between the drain plug and oil pan. Ive found that in a bind, you can reuse them at least a few times, but they are cheap to replace.
