Front end vibration after replacing CV Boot on 99 Prelude
Old Jan 23, 2008 | 10:14 AM
benyz250's Avatar
Default Front end vibration after replacing CV Boot on 99 Prelude
I replaced the inner CV boot on the driver of my 1999 Prelude and now that its all been put back together, I have a bad vibration over 60mph and when I take my foot off the gas and don't use the brake
Old Jan 23, 2008 | 11:42 AM
bluedlude's Avatar
Default Re: Front end vibration after replacing CV Boot on 99 Prelude (benyz250)
you may not have noticed your CV boot being damaged for quite a while in which case the axle itself is probably bad now. what did you pay for the CV boot? arent they like $30? and a new axle with lifetime warranty is like $75
Old Jan 23, 2008 | 12:02 PM
benyz250's Avatar
Default Re: Front end vibration after replacing CV Boot on 99 Prelude (bluedlude)
The boot was $15.00, but there was no not even a slight issue before. Do you think that I could have put it all back together wrong. I know that I tighten all the bolts as hard as I could. Is it possible that I screwed up the ballance?
Old Jan 23, 2008 | 12:19 PM
bluedlude's Avatar
if everything was seated and torqued the way it is supposed to be you should have no problems.
GSR936
Feb 26, 2009 02:59 PM
sohcef9
15
Oct 2, 2005 06:39 AM
GReddy212
Aug 4, 2005 11:37 AM
zeumer
Nov 30, 2004 04:41 AM
andrewasf77
Jun 10, 2004 08:59 AM
