speedometer gear keeps getting damage..
i just replaced my vss on my 89 honda civic hatchback si..it has a 89 crx si transmission and my vss keep getting messed up. so my speedometer isnt working. what seems to be the problem??????
There is no need to open up another thread when you already started one https://honda-tech.com/zerothread?id=2205490
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pin0y209 »</TD></TR><TR><TD CLASS="quote">i replaced the whole vss..when i took out the gear.it was messed up again..could it be something in the transmission that spinning the gear damaging the gear???</TD></TR></TABLE>
Could be that the plastic gear on the differential that transfers to the VSS is stripped. Are you using a mechanical or electronic VSS?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pin0y209 »</TD></TR><TR><TD CLASS="quote">im using a mechanical vss. would it be hard to replaced plastic gear on da differential???</TD></TR></TABLE>
Can you disassemble a transmission and differential?
I'd be willing to put my money on you either using the wrong one or not having it pushed in all the way. Although, you may have damaged te gear on the diff by putting it in wrong in the first place...
I'm just making assumptions though, not calling you dumb or anything. Try shining a flashlight into the VSS hole to see if your speedo gear is damaged.
GameBoyeas
Jun 6, 2017 01:35 PM
I Gotta Question
12
Oct 27, 2008 09:52 AM
Turbo Dan
10
May 15, 2008 11:25 PM
