ID on head '97 coupe
Old Jan 23, 2008 | 06:54 AM
evildeadbadguy's Avatar
Default ID on head '97 coupe
Hello all, I have a 97 civic that I have recently picked up. Its a real nice little car, has some suspension work done and i was looking and my engine bay today and noticed i have the factory d16y7 block which I am pretty sure was originally non vtec.. I bought the car because it has a headgasket leak and I was looking at it today, I see a vtec solenoid not wired up and I tried to find a head part # but all i found on her was p08-2 and faintly in junkyard marker its says 1993Y and D15B....could anyone ID this head, is it junk?
Old Jan 23, 2008 | 06:57 AM
97Ej6mike's Avatar
Sounds like you have the D15B if you have a VTEC solonoid. No, D15B's are not junk. JDM D15b's are the highest HP D-series motor that come stock from the factory as far as i know.
Old Jan 23, 2008 | 07:09 AM
Default Re: (97Ej6mike)
well the block is a d16y7 block, but the head as a solenoid on the left side (standing in front) which I would assume was a vtec solenoid but the wire from the sole. runs to the plug and then the plug is open ended. So the solenoid is deffinatly not being powered.
Old Jan 23, 2008 | 10:11 AM
Default Re: (evildeadbadguy)
OK updated...found the part number it is a d16z6 head (d16y7 block) but it looks like they swapped the z6 head on and did not bother hooking up the vtec or swapping intake manifolds (my intake manifold is ****)
any suggestions on wha i should do to utilize this head?
Old Jan 23, 2008 | 01:00 PM
97Ej6mike's Avatar
Yes, hook up VTEC, lol.
Old Jan 23, 2008 | 01:25 PM
well my ecu is a non vtec (pe3 i beleive), looks like the PO just threw the **** on
green99civic
Feb 27, 2010 12:03 PM
sony224422
Nov 9, 2008 07:47 PM
97civicsedan
May 10, 2005 08:33 AM
Daniel_san
15
Sep 6, 2004 11:04 AM
nickwilmot
Sep 13, 2003 10:20 PM
