weird noises wen i turn my steering wheel
i was wondering what could be the problem everytime i turn my steering wheel i can hear like metal scraping or something similar is it bad? its pretty loud
Are you running any type of lowering suspensions and/or after market sized tires/rims, etc? If so, then list all the specs and which year, make, model of car it's on so we can try to help you more thoroughly.
... Just a thought but I recently had some weird sounds when I made sharp turns and it turned out to be my sway bar bushings being worn out but then not sure if that would cause a 'metal to metal' type sound like you are hearing. Maybe a mixture of both rubber/metal possibly.....anyway....
I have the same problem, the tire is rubbing ithe inside of the wheelwell(sp?). If you take your tires off you will see where it is rubbing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SneezinCD5 »</TD></TR><TR><TD CLASS="quote">tire is rubbing </TD></TR></TABLE> yup..possible problem as well. i was gonna mention that but then you said metal to metal..so..
Fender liners are known to fall down from time to time. They are only help on by small plastic clips.
In any case, why don't you post your set up. Like what car you have, what modifications you have done to the wheels....etc
its a 95 civic its lowered on hr springs and i have si rims on it and would it be any harm to the car if i dont fix this problem
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92-95-04-06-civic »</TD></TR><TR><TD CLASS="quote">its a 95 civic its lowered on hr springs and i have si rims on it and would it be any harm to the car if i dont fix this problem</TD></TR></TABLE>
What size tires?
And yes, harm can definitely happen.
What size tires?
byronl
Jul 22, 2006 05:30 PM
