1600 Dohc si engine swap to b16a
Old Jan 22, 2008 | 07:38 PM
jonezyboy6's Avatar
Default 1600 Dohc si engine swap to b16a
HEy was wondering if anything needs to be changed to fit a b16a in my 1989 Civic SI???? heeelp please
Old Jan 22, 2008 | 07:46 PM
Crx Jimmy's Avatar
Default Re: 1600 Dohc si engine swap to b16a (jonezyboy6)
here we go again
Old Jan 22, 2008 | 07:54 PM
Mr.Meowsome's Avatar
Default Re: 1600 Dohc si engine swap to b16a (Crx Jimmy)
read read read https://honda-tech.com/zerothread/1508680 save yourself a lot of grief
Old Jan 22, 2008 | 08:50 PM
gursh d's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jonezyboy6 &raquo;</TD></TR><TR><TD CLASS="quote">HEy was wondering if anything needs to be changed to fit a b16a in my 1989 Civic SI???? heeelp please</TD></TR></TABLE>
http://www.droppedcrxsi.com
and there's a write-up/how-to in the FAQ
Old Jan 23, 2008 | 01:38 PM
whiteknightef's Avatar
Default Re: 1600 Dohc si engine swap to b16a (gursh d)
we should start a tally on how many noobs ask about swapping an engine that has been swapped for the last 20 years. If you are on the list then you get things taken from you.
Old Jan 23, 2008 | 02:01 PM
MagnaniEG6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gursh d &raquo;</TD></TR><TR><TD CLASS="quote">FAQ </TD></TR></TABLE>
lol, that pretty funny
Old Jan 24, 2008 | 04:53 AM
StorminMatt's Avatar
Default Re: 1600 Dohc si engine swap to b16a (whiteknightef)
Then again, I think the situation might be a little different with this guy. According to his signature, he is from New Zealand. Because this is basically an American site, the terminology that is used there is likely going to be somewhat different than what is generally used here. Notice, for example, that he asks about swapping a DOHC SI to a B16A. We call the stck motor he has motor a ZC here. And, because this is likely a foreign term, he would never know to search for 'ZC'. And even if he did, not much would come up. FEW people swap from ZC to B16A around here. He would also not likely know that the mounts are the same as in USDM CRXs, or that a mount kit is needed because a search for DOHC SI would certainly not bring up a car that has a ZC stock. Rather, it would probably bring up a swap in a USDM SOHC SI to a DOHC motor like a B16A. And this guy pobably doesn't know this is basically the same swap.
Another_Si_Guy
15
Jul 17, 2015 04:36 PM
loba
Mar 25, 2008 09:21 AM
murray195
May 1, 2007 02:39 AM
blk_EK
14
Dec 1, 2006 10:27 AM
Leviata-N
Aug 13, 2004 02:10 PM
