my hood!
Old Jan 22, 2008 | 06:04 PM
gavinoauto's Avatar
Default my hood!
i have a k20a2 swaped on a 1990 crx and my hood wont clear it closes but the passenger side has a big gap between the fender and the hood.
what can i do to make it clear or atleast make it
look cleaner??
Old Jan 23, 2008 | 08:28 AM
twiztid17thninja's Avatar
Default Re: my hood! (gavinoauto)
get a different hood i have heard the jdm sir hood will clear but you may need one with a bigger hoodscoop or better yet sell the k series and go d series....just kidding...kind of
Old Jan 23, 2008 | 09:13 AM
wiZCo's Avatar
Stouts 'n' Scotch
Check out some K-series build thread in here or visit http://www.k20a.org.
From what I've seen, it does look like you can use the JDM hood because it's raised in the middle.
Old Jan 23, 2008 | 09:16 AM
JustAnotherRex's Avatar
Default Re: (wiZCo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wiZCo &raquo;</TD></TR><TR><TD CLASS="quote">Check out some K-series build thread in here or visit http://www.k20a.org.
From what I've seen, it does look like you can use the JDM hood because it's raised in the middle.</TD></TR></TABLE>
Yep.
Or you could go the ghetto route if you've run out of money and aren't worried about your windsheild - SHIMMING!
Or custom cowling. Either would work for you, although might not look the best.
I'm still envious of you K guys.
Old Jan 23, 2008 | 11:25 AM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: (JustAnotherRex)
Hey hey nothing is wrong with a few washers
Old Jan 23, 2008 | 12:57 PM
~sp33~'s Avatar
EFB055
Imagine how many washers you'd have to buy... Might as well get the SiR hood.
Old Jan 23, 2008 | 02:50 PM
Ass$nyper's Avatar
Default Re: (~sp33~)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ~sp33~ &raquo;</TD></TR><TR><TD CLASS="quote">Imagine how many washers you'd have to buy... Might as well get the SiR hood. </TD></TR></TABLE> 4 doesn't seem like a lot.
All I needed on my lsvtec.
Yea, you are right... 4 washers I had laying around is cheaper then a new hood.
Personally I like my c/f zc hood
Old Jan 23, 2008 | 04:32 PM
gavinoauto's Avatar
ok i forgot to mention i have a sir hood i even trimmed the inside of it but it still doesnt clear i even put washers but it still hits idk what to do??
Old Jan 23, 2008 | 04:39 PM
Default Re: (***$nyper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ***$nyper &raquo;</TD></TR><TR><TD CLASS="quote"> 4 doesn't seem like a lot.
Personally I like my c/f zc hood </TD></TR></TABLE>
I like my CF ZC hood too. Got it sitting right now also.
I'd be worried about having the latch not holding quite right at the angle from too much shimming though.
Old Jan 23, 2008 | 04:41 PM
Default Re: (gavinoauto)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gavinoauto &raquo;</TD></TR><TR><TD CLASS="quote">ok i forgot to mention i have a sir hood i even trimmed the inside of it but it still doesnt clear i even put washers but it still hits idk what to do??</TD></TR></TABLE>
Show us pictures of it.
Old Jan 23, 2008 | 06:51 PM
Ass$nyper's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JustAnotherRex &raquo;</TD></TR><TR><TD CLASS="quote">
I'd be worried about having the latch not holding quite right at the angle from too much shimming though.</TD></TR></TABLE> When I had my GSR I didn't shim at all, my lsvtec 2 washers each side. No biggy at all, i've been on an open track at over 100 with no issues
Old Jan 23, 2008 | 06:55 PM
gavinoauto's Avatar
i will post a pic soon need a camera first
well i put 3 washers on each side still hits the
valve cover=[[
Old Jan 23, 2008 | 07:01 PM
crx2nr822's Avatar
It should work, normally you have to cut out most of the webbing out of the SIR style hood, but it should shut fine after that. Your using the Hasport mounts correct?
Old Jan 23, 2008 | 07:06 PM
gavinoauto's Avatar
yes i did cut out the webbing but it still wont clear all the way and yes hasport mounts is what im using
Old Jan 23, 2008 | 07:17 PM
gavinoauto's Avatar
but thats the gap
Old Jan 23, 2008 | 07:36 PM
crx2nr822's Avatar
Get a pic of the motor and the webbing part of the hood also......its kinda hard to tell but it looks like it goes down and not up in the center like the SIR style hood. Need better pics though.....what kind of hood is that anyway?
Old Jan 23, 2008 | 08:18 PM
gavinoauto's Avatar
op
Old Jan 23, 2008 | 08:31 PM
crx2nr822's Avatar
Default Re: (crx2nr822)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx2nr822 &raquo;</TD></TR><TR><TD CLASS="quote">Get a pic of the motor and the webbing part of the hood also......</TD></TR></TABLE>
Old Jan 24, 2008 | 10:14 PM
gavinoauto's Avatar
i will get the
pics of engine and webbing soon
well i need help on the rear brakes
i want to convert them to disc brakes but
idk what parts i need from the integra
Old Jan 24, 2008 | 10:53 PM
nihad's Avatar
Keep it off ha ha. Get a stock hood and put a hole in it and get a wrx hood scoop and make it look sick. Or that what i would do or any cool looking scoop.
97jdmdc2gsr
Mar 2, 2006 05:34 AM
Sparco_TypeR
Apr 7, 2004 01:58 PM
ViperRedCRX
23
Jun 6, 2003 10:45 AM
xJ.SLOTHx
Apr 13, 2002 07:24 PM
