Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
how to remove panal?
Old Jan 22, 2008 | 11:11 AM
Bulli Kid's Avatar
Default how to remove panal?
i will be installing a sub in my car and will need to run some wires along drivers door and passenger door. Does any one know how to take those plastic things off?
Ps were can i wire up the remote wire? i was thinking to an accesory fueze but i couldnt find one.
Old Jan 22, 2008 | 04:24 PM
FBPSidan's Avatar
Default Re: how to remove panal? (Bulli Kid)
which panels are you referring to? ive done several installs in civics...its pretty easy. Most of the panels are clipped in with a few screws. You want remote turn on wire from behind the deck? Do you have navi? stock radio?
Old Jan 22, 2008 | 06:33 PM
Bulli Kid's Avatar
Default Re: how to remove panal? (FBPSidan)
well i am running my power inside my fender, and want to run it along the bottom of the doors under those plastic covers. (ps. 4 dr) Its a stock deck and i don't really want to take it out but if i have to i will. my friend said in his car he used an accessory fuze and connected the remote wire to that. If that would be possible it would be easy and i could run it along with the power cable to the trunk.
I will have to use a line out converter also. To get signal from rear, i have heard that is the only way when using the stock deck.
Still have to get one do you recommend any?
Old Jan 22, 2008 | 06:50 PM
Nighthawk R18's Avatar
a pannel popper would help. i broke one of mine even using one but you cant notice.
damn lemme go look at my set up real fast. i too am running subs with stock headunit.
Old Jan 22, 2008 | 06:53 PM
Bulli Kid's Avatar
Default Re: how to remove panal? (Nighthawk R18)
thanks night hawk, let me know
Old Jan 22, 2008 | 06:56 PM
if i had a decent pair of AA batteries you'd have pics by now.
my rechargables are charging
Old Jan 22, 2008 | 06:58 PM
Bulli Kid's Avatar
Tke your time man as long as you get the pix in before Friday I will be Very happy.!!
Tahnks for the help man!
and I love pix!!
Old Jan 22, 2008 | 07:12 PM
well while i sit here and wait ill tell you how to take off the door pannels. i didnt need to remove them during the power/remote turn on wire but i took it off any just to see what it looked like lol.
keep in mind i have a coupe. might not be exactly the same.
there are 3 phillips screws holding it down, 2 under the left arm rest on the door (driver side) and 1 inside the handle. remove them.
from the bottom, pull outward. if you can feel that no more tabs are attached, pull up ward.
reverse directions to put back on
Old Jan 22, 2008 | 07:27 PM
Bulli Kid's Avatar
No wait. i might have wrote it wrong. I don't need to take of the doors. ahah
that plastic thing under the door. the other plastic that hold the carpet down i guess.
Old Jan 22, 2008 | 07:30 PM
Bulli Kid's Avatar
this is what i need to know how to remove. i will run the power wire though there.
Old Jan 22, 2008 | 07:55 PM
okay, i may have done too much, but i sincerely hope this helps you
along the way i removed the drive seat belt and B pillar pannel to run the power/remote turn on wire easily. i also removed my back seat to make the running wire easier. under the backseat is where i tucked all the wires
remove the screw and deadpedal. pull (purple) towards the center console to remove the tabs. then UP to relieve the clips. pannel popper recommended. pannel surrounding the hood latch also has to be removed for easier tucking
blue and red represent power and remote turn on (everything tucked)
i pinch the remote turn on wire to fuse 35. upped the factory 7.5 amp fuse to a 10 amp.
zoomed out.
engine bay tuckage
set the fuse there.
power wire leading to grommet.
about 8 inches west of the brake booster, there is a squarish rectangularish rubber grommet, i ran the power wire through there. a snake would be helpful.
zoomed out.
as for the RCA wire, i cut off the 2 male connector pieces, stripped them and "T-Tapped" the positive negative to my rear right speaker.
all wires are tucked under the backseat.
annnd just for kicks
Old Jan 22, 2008 | 07:57 PM
hondamanforlife's Avatar
just pull it up! nothing much holding it down. as far as remote goes if your using the stock radio you will need a line level converter. pull the connection from your current sub (if si) tap into it and connect the converter. the converter powers up from the radio feed to the sub and the remote wire on the converter goes to the amp. I have a peripheral converter that cost about $30. you should be able to get one at any sterio shop. good luck hope this helps!
Old Jan 22, 2008 | 08:07 PM
Bulli Kid's Avatar
Default Re: how to remove panal? (hondamanforlife)
Nighhawk, nice job very helpful. will do the same thing with the remote wire. The 07 civic doesn't have that hole in the firewall by the a accelerator so i am using a different rout. Would i have to up the fuze to a 10 or will the current one 7,5 be ok?
and as for the line out converter. Im still confused. you only tapped into 1 speaker right?, because you are only running one sub?
"as for the RCA wire, i cut off the 2 male connector pieces" the male connectors are the ones that plug into the amp or just the wire that goes to the speaker?
Old Jan 22, 2008 | 08:08 PM
Bulli Kid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondamanforlife &raquo;</TD></TR><TR><TD CLASS="quote"> the converter powers up from the radio feed to the sub and the remote wire on the converter goes to the amp. ! </TD></TR></TABLE>
the converter has a remote wire? i though it goes to the amp
Old Jan 22, 2008 | 08:15 PM
thanks!
but my civic is an 07. are you talking about the rubber grommet in the firewall? there is no hole by the gas pedal. its just a bad angle but the power wire runs up more in the first pic i posted. but if you can find a different route, coo.
i gave the 7.5 amp fuse a lil more juice to avoid problems. i gave it a 10 just to be safe.
yes i only tapped 1 speaker with the RCA wires. that ran directly to my amp. the other end of the RCA wire had the male connector pieces that just plugged directly into the amp.
i am running 2 subs, 2 10inch. from EACH sub i have 8 guage ( i think) of speaker wire that going to my 2 chan amp. i bridged it at the amp for more power.
Old Jan 22, 2008 | 08:17 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondamanforlife &raquo;</TD></TR><TR><TD CLASS="quote"> just pull it up! nothing much holding it down. as far as remote goes if your using the stock radio you will need a line level converter. pull the connection from your current sub (if si) tap into it and connect the converter. the converter powers up from the radio feed to the sub and the remote wire on the converter goes to the amp. I have a peripheral converter that cost about $30. you should be able to get one at any sterio shop. good luck hope this helps! </TD></TR></TABLE>
this job does not require messing with the headunit whatsoever
edit: sorry i read that wrong, i didnt use a line level converter.
Old Jan 22, 2008 | 08:27 PM
Bulli Kid's Avatar
ahh i get it now. Kool im glad it works for you without a line out converter. never thought of that.
8 awg for speaker wire. dang thats pretty big. Imo but whatever works right
im pretty sure there is an extra 10 fuze in the engine bay area where the fuzes are so ill just pull one from there. Going to go to Best buy try to get a line out converter if ot goign to order one.
ps. Should i have to tap into both speakers in the rear or will one be enough since i am only using 1 sub?
Old Jan 22, 2008 | 08:33 PM
lol i work for a car audio shop and we have ROLLS and rolls of 8 guage speaker wire, so whatever
should be an extra 10 in your fuse box, yes.
you can only tap into 1 speaker using the RCA wire, since theres only 1 +/- input in the amp.
Old Jan 22, 2008 | 08:38 PM
Bulli Kid's Avatar
alright man thanks for the help, now i have it all figured out. Running the wires will probably be the hardest part. Im goign to get all my stuff together so i can install it on Sunday when i get my wiring kit. If i get stuck ill ask for some help again hehe.
i am gona crash now , thanks again
ps. how does your sound system sound?
is it decent enough?
Old Jan 22, 2008 | 08:41 PM
yee
edit:
very decent, cant go wrong with JL Audio. im using their lowest subwoofer version. that **** HIITSSS!
but i turn it down to evenly blend with the stock speakers. very good indeed.
i paid 300$ for 2 JL 10's, the box and amp and all the hardware. did the install myself at my work place.
Old Jan 22, 2008 | 08:46 PM
Bulli Kid's Avatar
ahh nice.
all im paying for is the wiring kit $30 and the converter about $30
i got a free sub and a free amp from my bro.
the amp sucks though ahaha only 1 channel is working and giving off a really low rms, around 200 or so i believe, IDK they don't have the specs for it anymore its an old amp. the sub has 500 rms.
Old Jan 22, 2008 | 08:49 PM
well hey its an upgrade from stock
Old Jan 23, 2008 | 05:00 PM
Bulli Kid's Avatar
So i went to best buy and got a converter for 28 total.
do i have to connect the wires from the converter to the left and right speaker or do i just tap into one?
and for the remote when i wire it up the the accessory fuse do i have to wrap it around both sides of the fuse?
Old Jan 23, 2008 | 06:32 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bulli Kid &raquo;</TD></TR><TR><TD CLASS="quote">So i went to best buy and got a converter for 28 total.
i just tapped into 1 so i guess 1 should be good.
and for the remote when i wire it up the the accessory fuse do i have to wrap it around both sides of the fuse?</TD></TR></TABLE>
1 side should be good enough
Old Jan 23, 2008 | 06:45 PM
Bulli Kid's Avatar
Thanks again cant wait to install on Sunday.
Man today was a bad day!
not only that its my birthday i just got back from the police station to file a hit and run on my bros civic. Sucks
