Spare tires for 16" rims
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrid90 »</TD></TR><TR><TD CLASS="quote">What do you guys use as a spare for 16" rims with 205/45/16? This is for a 91 DA. Thanks</TD></TR></TABLE>
A tire with wheel...? Or did you mean what brand/make of rim? Any Rota or cheap aftermarket 16 will do. I'd buy some trashed up, curbed up, beat up, and molested but still holds air and drivable 16 for $50 or less.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan »</TD></TR><TR><TD CLASS="quote">I don't really understand what you mean by "spare". Can you elaborate a bit?</TD></TR></TABLE>
Sorry, guess I wasn't too specific with my question..
Well since I just got some 16" rims with 205/45/16 tires, I was wondering what you guys carry around in your car as a spare just in case one of the tires blow out.
The DA stock spare is equal to a 14" wheel so I guess I can't use my stock spares so I'm curious if you can get a 16" spare from another car...
But from 98babie's response, I guess you can just buy a cheap as 16" rim then.,,,
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan »</TD></TR><TR><TD CLASS="quote">Your stock spare will work fine. </TD></TR></TABLE>
The reason the stock spare works fine is that, even though the diameter of the wheel on a 205/45-16 tire is two inches bigger than stock, the outer diameter of the tire is the same size as stock. So yes, your stock spare wheel and tire will work fine - assuming that you still have your stock brake calipers. If you got the bigger wheels in order to fit a big-*** aftermarket brake setup, then the stock spare wheel/tire might not fit, but other than that exception, it's fine and will work fine as a spare for your 205/45-16 tires. No need to get anything else.
hahah how ironic cuz a week after I posted this topic.. my freakin tire blow out on the freeway and I had to use the stock spare.. it fits but it sits lower than the rest .. I mean much lower to the point my mudguards rub on the ground so I couldn't drive so had to jack up the car again and removed it...
Guess I was slammed that's why.. hope that **** never happens again...
What tires should i go for my 16" grids...205/45/16 or 205/40/16.....pics would help on any 16" rims
305JDM
Feb 27, 2005 08:59 PM
305JDM
Feb 25, 2005 07:17 AM
