will a 88-91 jdm zc lsd be a direct fit in a 90 dohc zc tranny ?
Old Jan 22, 2008 | 08:20 AM
johngrady's Avatar
Default will a 88-91 jdm zc lsd be a direct fit in a 90 dohc zc tranny ?
Old Jan 22, 2008 | 08:23 AM
wiZCo's Avatar
Stouts 'n' Scotch
Yes.
Just make sure the new one is shimmed out properly and you'll be golden.
Old Jan 22, 2008 | 08:49 AM
johngrady's Avatar
Default Re: (wiZCo)
ok so my zc axels will fit. I am also considering my si final drive in it.
Old Jan 22, 2008 | 08:50 AM
johngrady's Avatar
Default Re: (johngrady)
i mean putting my si final in with it .
Old Jan 25, 2008 | 06:29 PM
JOE BD-0's Avatar
Didn't one of the zc trannys come with the 4.25 si fd gear?......good luck........
Old Jan 25, 2008 | 08:41 PM
johngrady's Avatar
Default Re: (JOE BD-0)
lost the zc lsd sale by $5 with 2 seconds to go on ebay and it turns out quaife doesnt make one for a zc L3 trans with 27 spline iner cv joint and half shaft.
Old Jan 25, 2008 | 08:46 PM
johngrady's Avatar
basicly im over the thought of a lsd zc tranny or rebuilding my si trans with the diff plus new axles. rebuilds are worthless . Raxels.com
Old Jan 26, 2008 | 03:27 PM
wiZCo's Avatar
Stouts 'n' Scotch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by johngrady &raquo;</TD></TR><TR><TD CLASS="quote">basicly im over the thought of a lsd zc tranny or rebuilding my si trans with the diff plus new axles. rebuilds are worthless . Raxels.com</TD></TR></TABLE>
What's wrong with rebuilding? You can fershen up the internals for $250 or so if you can do the work yourself and basically get a new trans.
Old Jan 27, 2008 | 07:01 AM
jlicrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by johngrady &raquo;</TD></TR><TR><TD CLASS="quote">it turns out quaife doesnt make one for a zc L3 trans with 27 spline iner cv joint and half shaft.</TD></TR></TABLE>that would be incorrect
http://www.quaife.co.uk/Honda-...ntial
johngrady
Jan 24, 2008 07:57 PM
Ahknodd
Jul 24, 2005 10:07 PM
Mr.Noodles
Feb 16, 2004 08:42 PM
