HELP ON FUEL INJECTORS!!
Could be a bad resistor box, computer, injectors, fuel pump. could be alot of things check fuel pressure first. then Check to see if you are getting injector pulse. A set of noid lights will tell you that. you could use a multimeter to see if there is voltage to the resistor box. there could be alot of stuff to check.
billy hoang
Northeast (Sales)
Feb 17, 2011 10:11 AM
eg2phosizzle
Jan 26, 2006 09:48 PM
