which is better to get?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92civicx »</TD></TR><TR><TD CLASS="quote">supertech
yes, he's asking about supertech parts.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ej1252 »</TD></TR><TR><TD CLASS="quote">supertech stainless steel or nitride valves?
with which top, flat or dish?
idk if this matters but, head(B16) is built for a 235whp goal.</TD></TR></TABLE>
I can't really advise you, but the people here that can are probably going to need more info.
You could always start with what block? pistons? compression ratio? what is the car being used for?
also, you can always talk to supertech personally about your setup.
o my fault, the set up right now:
00 em1 chassis
darton 84mm b16a block
12:5:1 cp pistons
eagle rods
B16a2 head
stock throttle body & intake manifold
port & polish (3 angle valve job)
toda spec b cams
toda valve springs
skunk2 retainers
toda cam gears & timing belt
arp headstuds, rod bolts, main studs
rc 370cc injectors
just need info on the valves and then assembly.
00 em1 chassis
12:5:1 cp pistons
eagle rods
B16a2 head
toda spec b cams
toda valve springs
skunk2 retainers
rc 370cc injectors
