Interior components for Tan Interior
Old Jan 22, 2008 | 02:39 AM
toyomatt84's Avatar
Sanji
Default Interior components for Tan Interior
I was curious as to if the following highlighted parts were ever available for a 1990 Honda Civic hatchback, with a Tan interior.
Old Jan 22, 2008 | 08:46 AM
MagnaniEG6's Avatar
Default Re: Interior components for Tan Interior (toyomatt84)
I never seen an audio consol but the arm rest I am dam sure I seen it once before.
Old Jan 22, 2008 | 08:51 AM
ESP.net's Avatar
I would say yes, JDM EF8's limited editions I believe had a tan leather interior option and id imagine it was available for the EF9's as well...
Being able to find it in good condition I will already tell you this impossible... just a fact tan goes bad easily and on a 15+ year old car and on top of being a limited edition...
Old Jan 22, 2008 | 01:50 PM
welfarepc's Avatar
the 94-00 integra came with tan interior... center console swap? heh
Old Jan 22, 2008 | 02:02 PM
Killer D's Avatar
Look up the CRX exclusive....It came with all tan interior...It wont have that audio console because it isnt a civic, but if you were willing to do a full dash/console swap, it would work out.
Old Jan 22, 2008 | 02:44 PM
89hatcher's Avatar
if it was brown, the audio, shift counsel and the armrest are arround and i've seen it cause i have it. good luck on your find if its tan you would probably find the armrest only cause the crx dash is different from the hatchback. the only way to get a tan interior is to paint it for the hatch
Old Jan 22, 2008 | 02:54 PM
welfarepc's Avatar
oh ive seen a tan interior 88-91 4Dr Civic... it was gold, and had cruise, power steering, ac, auto with tach, etc... not sure if that would fit or not? gl
Old Jan 22, 2008 | 06:30 PM
~sp33~'s Avatar
EFB055
Default Re: Interior components for Tan Interior (ESP.net)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ESP.net &raquo;</TD></TR><TR><TD CLASS="quote">I would say yes, JDM EF8's limited editions I believe had a tan leather interior option and id imagine it was available for the EF9's as well...
Being able to find it in good condition I will already tell you this impossible... just a fact tan goes bad easily and on a 15+ year old car and on top of being a limited edition... </TD></TR></TABLE>
No it wasnt.
That civic's interior is pimp
http://cgi.ebay.com/ebaymotors...ZWDVW
Theres your armrest matty.
And i have seen that audio console, i might be able to ask around to see if they guy i saw it with still has it for sale.
Old Jan 22, 2008 | 06:39 PM
SlobberGoat's Avatar
Default Re: Interior components for Tan Interior (~sp33~)
Actually, the JDM special-editions (black cars with tan interiors + glasstops) were all ZC EF7's... not B16 EF8's.
Old Jan 22, 2008 | 07:33 PM
AK_CRX's Avatar
Dupont makes a really kick *** one part (no mixing with other components) interior paint. You can get it matched to any interior color at a proffesional paint shop that sells dupont. I used it on a restoration job for a '67 Olds Toronado, turned out like brand new. Requires a gun/compressor setup and a decent place to shoot but definately worth the trouble. whats nice is you don't have to spray it on heavy so it dries quickly having little time to attract dust and dirt while drying. since you can put it on so thin even an amatuer could spray it and get it perfect. Just have to prep your parts with a wet gray scotchbrite with an abrasive soap, wipe with alcohol (wax/grease/silicone remover) use an aerisol plasic primer spray, then shoot it...
Old Jan 22, 2008 | 10:34 PM
toyomatt84's Avatar
Sanji
Default Re: Interior components for Tan Interior (AK_CRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AK_CRX &raquo;</TD></TR><TR><TD CLASS="quote">Dupont makes a really kick *** one part (no mixing with other components) interior paint. You can get it matched to any interior color at a proffesional paint shop that sells dupont. I used it on a restoration job for a '67 Olds Toronado, turned out like brand new. Requires a gun/compressor setup and a decent place to shoot but definately worth the trouble. whats nice is you don't have to spray it on heavy so it dries quickly having little time to attract dust and dirt while drying. since you can put it on so thin even an amatuer could spray it and get it perfect. Just have to prep your parts with a wet gray scotchbrite with an abrasive soap, wipe with alcohol (wax/grease/silicone remover) use an aerisol plasic primer spray, then shoot it...</TD></TR></TABLE>
I didn't know you could get that Vinyl Dye stuff custom matched. That may be worth a look into.
Thanks for the suggestions thus far, everyone. They'll definitely come in handy.
PS. The DC2 console doesn't quite line up with the hatch's, so I'll pass on that.
Old Jan 23, 2008 | 06:17 AM
Boosted Chemist's Avatar
Pm 408wdy, he recently did a rhd conversion in his std and painted/dyed the sir dash (black) to tan.
Old Jan 23, 2008 | 10:02 PM
toyomatt84's Avatar
Sanji
Default Re: Interior components for Tan Interior (Boosted Chemist)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boosted Chemist &raquo;</TD></TR><TR><TD CLASS="quote">Pm 408wdy, he recently did a rhd conversion in his std and painted/dyed the sir dash (black) to tan. </TD></TR></TABLE>
His dash is dyed? Turned out real well.
SOHCNightmare
Paint and Body
Jul 17, 2009 04:23 PM
BondoBuilder
Honda S2000
Apr 25, 2007 05:20 AM
Hayasa15
Feb 21, 2002 04:22 PM
