Gas in oil dipstick, Oil on ground
Old Jan 21, 2008 | 11:55 PM
88CRsXy's Avatar
Default Gas in oil dipstick, Oil on ground
Setup:
I have a d16a6 motor with a chipped 91 pm6 ecu and short ram intake. Everything else is stock. Recently swapped this motor in (motor was sitting for a year). I had an older d16a6, reused the intake manifold and tranny.
Problem:
I have oil leaking on the ground (haven't checked what's leaking yet cause it's raining pretty hard, no garage). I'm guessing it's the oil pump seal because it looked like it had a very slight leak when we pulled off the crank pulley.
After I noticed the oil leak, I made sure I had enough oil for a short drive (>10 miles). Turns out the oil was very clear, and smelled like gas.
Would an oil pump seal failure cause oil to seep into the crankcase?
Searched...seems like no one ever posts their end results or their solution.
btw, no cel codes
TIA
Modified by 88CRsXy at 1:14 AM 1/22/2008
Old Jan 22, 2008 | 12:56 AM
88CRsXy's Avatar
Default Re: Gas in oil dipstick, Oil on ground (88CRsXy)
bump for my daily...i'm immobile!!!
Old Jan 22, 2008 | 10:09 AM
88CRsXy's Avatar
anyone have ideals/suggestions?
Old Jan 22, 2008 | 11:37 AM
88CRsXy's Avatar
update: just changed my oil...it was very gritty and smelled like fuel
checked my injectors and the one closest to the distributor looked wet around the head. looked like my clutch cable was pinching the injector at the top because my new valve cover didn't have the hook for the clutch cable, so it was resting on this one injector.
should i change this injector? is it difficult to change? should i change all of them?
-TIA
Old Jan 22, 2008 | 12:57 PM
93civiceg6's Avatar
what set up do you have sohc with mpfi or dpfi dohc. or a dohc and how did the clutch cable get that much pressure on the injector
Old Jan 22, 2008 | 01:36 PM
VenWood's Avatar
Fuel is going past your rings. Check compression?
Old Jan 22, 2008 | 02:33 PM
88CRsXy's Avatar
Default Re: (93civiceg6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93civiceg6 &raquo;</TD></TR><TR><TD CLASS="quote">what set up do you have sohc with mpfi or dpfi dohc. or a dohc and how did the clutch cable get that much pressure on the injector</TD></TR></TABLE>
I have a sohc with mpfi.
The clutch hook near the distributor applied the pressure on top of the injector (on top of the plastic shield). The new valve cover doesn't have the clutch cable hook in the center of the valve cover, so the one hook by the distributor was taking all of the pressure.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VenWood &raquo;</TD></TR><TR><TD CLASS="quote">Fuel is going past your rings. Check compression?</TD></TR></TABLE>
will do once I get a chance, I don't have the tester?
could the oil leak by the oil pump/crank pulley cause fuel to leak into the crank case?
Old Jan 22, 2008 | 06:32 PM
~sp33~'s Avatar
EFB055
Default Re: Gas in oil dipstick, Oil on ground (VenWood)
I would check this first, this is what i think is happening.
scubacamper
Mar 24, 2016 10:24 AM
5.56
Dec 28, 2008 05:00 PM
mksliao
May 7, 2007 05:22 PM
civiccpedx
20
Mar 6, 2005 07:16 PM
