low idle on start up
d16y7 obd0 with a d15b7 intake mani. when the car is allready warmed up and i start it it barely wants to start it will idle super low but it will always start never dies. if i wait about 3-4 seconds it idles up to where its suposed to be and stays there all the time. the only time it idles low is when i first start it when its warm. other then that it idle perfect. is it a fast idle valve problem or iacv problem? i did take apart the fast idle valve under the tb and screwed the thing in all the way tight cause it was idleing way high before. could that be my problem?
When you opened up the FITV, did you clean it as well?
Have you cleaned the IACV? Your description sounds like it may be a dirty or malfunctioning IACV, or it could be coolant related (but you checked that already).
Any CELs?
Any CELs?
KimvdLinde
Jun 29, 2013 01:40 PM
roterx7
Jan 19, 2007 07:14 PM
