JDM H23 Vtec swap to a 96 Lude,,,P13 ecu
Im using a OBD 1 P13 ecu for the swap , does the p13 look for the crank position sensor .if so who does good chipping so i can eliminate this problem. due to the 2001 H23 vtec CPS is in the dizzy not on the block near the Crank pulley as in the stock H23a1.Wiring harness nightmare to follow...
OBD1 P13 doesn't look for the that pesky crank sensor... thats only a OBD2 prelude and accord thing...
If the JDM H23A has the crank sensor just leave it hanging...
