**Alaniz Street Master P72 cylinder head for B18C B16A LS VTEC**
Old Jan 21, 2008 | 10:42 AM
TrackSpeedRacing's Avatar
Default **Alaniz Street Master P72 cylinder head for B18C B16A LS VTEC**
***Street Master Alaniz P72 DOHC VTEC cylinder head + valvetrain w/o NO CAMS.***
ATTN: Motor has been dyno tuned with the block for sale below and made 205whp & 133wtq at DynoSpotRacing in San Jose. ALL MOTOR 1.8 LS VTEC! This is an easy 12 sec naturally aspirated setup!
(For those who want a better than stock head but are on a budget. Great choice for street/strip or road racing).
<u>Whats been done to this head?</u>
Complete visual inspection of complete head. Check all surfaces for straightness. Complete disassembly. Inspect all valvetrain parts for wear. Degrease and clean head of all oils. Street port and polish which is: (bowl port, gasket match 1 inches into runners only. Polish, deshroud and debur all chambers.) Street Master valve job. Resurface and hand lap head to customer specs, or up to .020 material removal. Reassemble complete head. Includes valve seals. **Less than 10K miles on head. Absolutely perfect condition!**
"Best flow improvements for each dollar spent."
Main Features:
**Omni Power flat faced valves**
**Supertech Valvesprings & Titanium Retainers**
**OEM Honda valve seals**
**Cam Caps**
**Cam plate holders**
$1350.00 OBO bay area local pick up.
Here are pictures of the actual motor that is being parted out for sale. You will only receive the parts listed above. Thanks.
***Acura Integra B18B1 complete shortblock assembly, B16 usdm pistons, and arp rod bolts***
ATTN: Motor has been dyno tuned with the head for sale above and made 205whp & 136wtq at DynoSpotRacing in San Jose. ALL MOTOR 1.8 LS VTEC! This is an easy 12 sec naturally aspirated setup!
"Excellent ring seal and makes good power! 250psi compression on 4 cylinders!"
$550.00 OBO bay area local pick up.
More pictures coming shortly...Thanks!
Interested in either the head or block? Give me a call at (510) 304-3216 for serious buyers only. Ready for immediate pickup!
$1800.00 FIRM bay area local pick up for both head and block package.
Old Jan 23, 2008 | 07:13 AM
Default Re: **Alaniz Street Master P72 cylinder head for B18C B16A LS VTEC** (TrackSpeedRacing)
All PMs replied to. Thanks!
g0at357
Feb 24, 2008 10:48 AM
TrackSpeedRacing
Northern California (Sales)
26
Feb 4, 2008 07:30 PM
BryanPendleton
Mar 3, 2004 12:28 PM
