si to dx b series swap axle question.
my boyfriend got a 1990 crx si with a b16 in it. just bought a 1988 dx hatchback shell. Can his b16 drop into the dx hatch without having to swap teh hubs out... or do i have to swap teh hubs to make the axles work? i belive the dx hatch is a 5speed if that makes a differrence. i searched HT but only came up with nothing in this case. help me out guys. thanx
https://honda-tech.com/zerothread/1508680
You don't need to switch hubs. The axles difference will be in the B-series intermediate shaft that D-series don't have.
so no matter if it is an 88 civic or 90 crx the axles from teh b series will work? there is no differnece in teh hub spline accepting the shafts?
is there a differnce in size between the 4 speed tranny drive shafts and the 5 speed tranny driveshafts?
If the hubs are a CRX/DX/Si then there is no problems. The hubs will be fine with B-series axles.
If it is HF/STD then it won't work and you will have to swap out hubs.
4 speed is STD unless someone has messed around with the hubs and put different axles in. So yes there is a difference between CRX/DX/Si 5 speed and the STD 4 speed/HF 5 speed.
You could also use 1986-1989 Integra axles with 1990-1993 Integra inner joints. This is certainly more work than using straight 1990-1993 Integra axles. But you will get a somewhat better fit. For instance, removal of the sealing rings is not required with this setup. But regardless of which axles you use, the 1990-1993 Integra intermediate shaft is the one you need.
Zawacki
12
Mar 8, 2008 08:44 PM
VtecKiDD
Mar 16, 2006 02:15 PM
