Sunroof help
I just put my sunroof back in the car after i patched and got rid of all the rust. Well now when i hit the motor button it moves really slow like its binding or something. I bent the front stops so there not hitting anything. Still really stiff. any thoughts?
Ok i was messing with the sunroof a little more and i noticed that if i pickup on the back side of it while its closing it will close all the way. Does there need to be shims or something that help lift it up?
check every screw and bolt point. you shouldnt be able to pick up on it very well. Check for alignment too. I would take it back out personally but thats up to you. Buy a book that helped me.
I tightened everything on the roof panel. When I lift on it the little slide arms are what move a little. I also noticed that when i the sunroof the fully close it sits lower on the driver front. I found a write up it says i may need to shim it. So ill go to the hardware store tomorrow and see about some thin washers
Well i got the sunroof back in and lined up but the only problem im having is when you go to close it, it will slide all the way forward but it doesnt always set down. Do i just need to lube it?
