Cheap Skunk2 Stage I Cams $200 and Skunk2 Intake Manifold (GSR) $60 shipped, CHEAP!!!!!
Skunk2 Intake Manifold - $60 shipped
Cheap because the Coolant port (that feeds into the head by the dizzy) is cut off....along w/ that mounting hole as well....some people do this in race applications, however it is worthless to me....Im sure you could rig up something if need be. Also, the ports have been lightly touched....looks to be port matched because there isnt too-too much port work on them. Last pic shows the cut part which I speak of.
Skunk2 Stage I Cams - SOLD
These are cheap because I was told they were B16 cams (which looked about right), however when I spec'd them out they came out to the old Skunk2 stage I specs....and the markings are consistent with that as well. Here are the specs that I got on them.
Intake Lift - 11.45mm (36.93 - 29.54 on the lobes X 1.55 rocker arm ratio)
Exhaust Lift - 10.92mm (36.55 - 29.50 X 1.55)
Modified by 95 integra at 8:56 PM 1/24/2008
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fibercation »</TD></TR><TR><TD CLASS="quote">Good deals!!</TD></TR></TABLE>
Thanks, glad somebody is noticing. I should've stated (as I did in the title) but the IM only fits GSRs...looks like ef0cmacro might be buying it as well.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hai_tech »</TD></TR><TR><TD CLASS="quote">dem that cheap bump for u</TD></TR></TABLE>
Thanks
Thanks
vntperformance
Apr 16, 2002 04:31 PM
