dizzy promblem
Hey guys , i need your experteee listen i have a 1993 honda civic hatchback with a 2000 type R swap done, now my car has been in the garage for 2 weeks and i finally need to actually use it asap. i know that i need a distributor but the million dollarquestion is WHich one obd1 or obd2. Which obd 1 distributor can i use and it would be very helpfully if you guys find it on ebay... i have been looking for it on ebay but im scarred to make a mistake thats going to cost me double anymore info please write back since i am going to be on this all night ( one more piece od info, im running a p06 chipped) thanks in advance
I believe it would be obd2 dizzy bcause u said 2000 type-R NOTE: here are some dizzy type-R code list and you'll be able to see and match compare on ur dizzy code here goes (TD85U)(TD86U)(TD87U)........
thankz but is it possible for the distributor right now that i have one be obd1 because if the block that i have is a 2000 R then the distributor needs to match up with the hole in the block. does the obd1 and the obd2 look similar i know for a fact that the coil in the distributor (old one) says the word Tec. can this be alil help to help me
RomesEM1
11
Oct 6, 2025 08:09 AM
GummyBeng
Feb 12, 2003 02:17 PM
