92 Accord TCM replaced, not the problem, what do I do w/the old one?
Had a diagnostic done for blinking D4, was told it was the TCM, replaced it with a used one w/less than 60,000 miles to it. didn't fix the problem. Found out later it was the transmission solenoid (thanks to a link from someone here that helped me pull the real code) I am keeping the TCM w/less miles to it in the car(mostly because I never got around to fixing the transmission solenoid until after the return period on the TCM expired) Anyhow, seems like the old one was fine to begin with(not fried on the inside or anything) so I have an extra. What can I do with it? Is there someone who buys them and rebuilds them (this one doesn't even need to be rebuilt, to my knowledge) Someone willing to risk buying one cheap? Like I said turns out replacing the TCM didnt fix the problem so my old one is likely just fine since once we cleaned the solenoid the D4 stopped blinking.
$30 if anyone wants it.
If this needs to be moved to the FS thread I can re post there.
Modified by dishka at 6:09 PM 1/22/2008
i having the same problem with the light keep on blinking on my 94 ex. I already changed both soleniods and still same. Can you give me that link you memtion in the post about finding the codes. Thanks
OnceIwasMuffin
May 5, 2014 09:36 AM
ScareyH22A
Jan 25, 2006 06:58 PM
jacanter
Aug 28, 2005 04:55 PM
