I need axle help...
Old Jan 20, 2008 | 05:09 PM
vtakef's Avatar
Default I need axle help...
Well I am getting ready to replace my axles but I am not sure what ones I need...
I have a jdm 97 itr, so I know the 98spec jdm itr has the 36mm axles but did the 96-97 jdm itr's that came with the 4x114.3 also have the 36mm axles or are they the 32mm axles.
Thank you for your help.
Old Jan 20, 2008 | 05:11 PM
migs's Avatar
Default Re: I need axle help... (vtakef)
Any USDM 94-01 Integra axle will work.
Old Jan 20, 2008 | 05:27 PM
Spids5's Avatar
Don't judge or question
Default Re: I need axle help... (migs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by migs &raquo;</TD></TR><TR><TD CLASS="quote">Any USDM 94-01 Integra axle will work.</TD></TR></TABLE>
What about the RS axles? Do the axles come with the abs rings?
Old Jan 20, 2008 | 05:28 PM
migs's Avatar
Default Re: I need axle help... (Spids5)
All 94-01 USDM Integra axles are the same with the exception of the ABS ring.
Old Jan 20, 2008 | 05:29 PM
SuckMyDOHC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spids5 &raquo;</TD></TR><TR><TD CLASS="quote">
What about the RS axles? Do the axles come with the abs rings?</TD></TR></TABLE>
Every aftermarket axle that I've seen comes with the abs rings, you just remove them if you don't have abs
Old Jan 20, 2008 | 05:38 PM
walker111's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by migs &raquo;</TD></TR><TR><TD CLASS="quote">All 94-01 USDM Integra axles are the same with the exception of the ABS ring.</TD></TR></TABLE>
Im pretty sure that type r axles dont have the rubber vibration dampener.... All others do....
Old Jan 20, 2008 | 06:53 PM
Bbasso's Avatar
Default Re: I need axle help... (walker111)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by walker111 &raquo;</TD></TR><TR><TD CLASS="quote">
Im pretty sure that type r axles dont have the rubber vibration dampener.... All others do....</TD></TR></TABLE>
Well...
Old Jan 20, 2008 | 09:35 PM
vtakef's Avatar
Thank you guys so much for all the help.
I will get some tomorrow. I do have abs so I need the ring. lol
Old Jan 21, 2008 | 03:59 AM
Ed 341's Avatar
Default Re: I need axle help... (Bbasso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso &raquo;</TD></TR><TR><TD CLASS="quote">
Well... </TD></TR></TABLE>
What is this showing? My stock ITR axles don't have that.
Old Jan 21, 2008 | 04:33 AM
sheekdude's Avatar
Default Re: I need axle help... (Ed 341)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ed 341 &raquo;</TD></TR><TR><TD CLASS="quote">What is this showing? My stock ITR axles don't have that.</TD></TR></TABLE>
Almost every Honda dealer axle i've seen has these rubber vibration damper on them... Idk why yours don't...
Old Jan 21, 2008 | 05:31 AM
Ed 341's Avatar
Default Re: I need axle help... (sheekdude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sheekdude &raquo;</TD></TR><TR><TD CLASS="quote">
Almost every Honda dealer axle i've seen has these rubber vibration damper on them... Idk why yours don't... </TD></TR></TABLE>
Are you talking about replacement ones?
Old Jan 21, 2008 | 06:35 AM
Bbasso's Avatar
What is showing, Raxles' Integra Type R axles. That have rubber vibration dampeners.
Old Jan 21, 2008 | 06:38 AM
walker111's Avatar
I was referring to OEM axles from HOnda(not Raxles).... My current and past ITR's didnt have them, my friends r didnt, and ed's dont I know mine are from the factory.
Old Jan 21, 2008 | 06:41 AM
Bbasso's Avatar
Ya I knew exactly what you meant
just adding to the confusion
Old Jan 21, 2008 | 06:56 AM
Ed 341's Avatar
What did that set go for? I know OEM ones are $400+
Old Jan 21, 2008 | 06:58 AM
EG6-DC2's Avatar
So if mine doesn't have them from the factory, then Honda did my car wrong? I can't believe that they would do something like that.
Old Jan 21, 2008 | 09:21 AM
Bbasso's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ed 341 &raquo;</TD></TR><TR><TD CLASS="quote">What did that set go for? I know OEM ones are $400+ </TD></TR></TABLE>
If OEM are too much then don't ask about these
But if you must... Call Marty up: http://www.raxles.com/
Modified by Bbasso at 1:32 PM 1/21/2008
Old Jan 21, 2008 | 09:32 AM
Ed 341's Avatar
If OEM are too much then doon't ask about these
Oh I thought these were a more economical alternative to OEM.
Old Jan 21, 2008 | 02:34 PM
R 01 1101's Avatar
Auto Zone life time waranty
Old Jan 21, 2008 | 03:08 PM
walker111's Avatar
Default Re: I need axle help... (R 01 1101)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R 01 1101 &raquo;</TD></TR><TR><TD CLASS="quote">Auto Zone life time waranty </TD></TR></TABLE>
I concur!
Old Jan 21, 2008 | 07:08 PM
EG6-DC2's Avatar
I concur!</TD></TR></TABLE>
x2, I just picked one up the other day for $65.
slow_db7
Apr 11, 2008 12:37 AM
benchmade
Northern California (Sales)
Jan 8, 2008 09:44 PM
posHonda
Apr 16, 2007 06:46 PM
Tommy_Gunns
Jul 27, 2004 08:11 PM
BlackNoise
Feb 10, 2004 10:26 AM
