transmission will not go into gear ???
Old Jan 20, 2008 | 12:14 PM
andrey320's Avatar
Default transmission will not go into gear ???
89 si stock
Transmission will not go into any gear with pedal fully depressed.
I had someone push the clutch in while I was looking. The lever that the cable is connected to does not seem to go up. What could cause this?
Thanks!
Old Jan 20, 2008 | 12:24 PM
GSX 4G63T's Avatar
too tight. The tension is too tight on the adjusting plastic nut on the tranny. Give it some slack
Old Jan 20, 2008 | 12:29 PM
andrey320's Avatar
adjusting the freeplay does not help....
Old Jan 20, 2008 | 12:30 PM
GSX 4G63T's Avatar
Inspect clutch cable.
Old Jan 20, 2008 | 12:33 PM
andrey320's Avatar
Thats what I thought too, but I could not pull the lever up by hand either....
Modified by andrey320 at 2:51 PM 1/20/2008
Old Jan 20, 2008 | 12:43 PM
GSX 4G63T's Avatar
remove the tranny clutch cable bracket
Old Jan 20, 2008 | 12:57 PM
andrey320's Avatar
Remove and ???
Old Jan 20, 2008 | 01:00 PM
GSX 4G63T's Avatar
it would be easier to adjust it and inspect the cable for kinks
Old Jan 20, 2008 | 02:01 PM
Targa250R's Avatar
be professional
Default Re: (andrey320)
Possible problems:
- improper cable adjustment
- broken clutch cable
- broken clutch pedal mount bracket
- broken clutch
Old Jan 20, 2008 | 02:32 PM
Tyson's Avatar
Default Re: transmission will not go into gear ??? (andrey320)
honestly, im in the exact same position as you. well, its not as serious as you seem to make it sound. my car sometimes doesnt want to get into first if i let it sit in neutral for too long. it just takes putting it back in neutral, pressing the clutch in and back out quickly to get the gears moving again and it goes from there. so it just takes a split second more to go after it turns green, probably just more annoying to the guy behind me.
and im maxed out of cable adjustment too. it just means its time to replace my clutch. not something im looking forward too either. im not quite sure if its related to not wanting to get into first, tho. either way, i need to get it done soon, hopefully before it quits on me...
Old Jan 20, 2008 | 02:36 PM
andrey320's Avatar
Thank you all for the input.
I will try to change the cable and inspect the bracket before changing the clutch.
Old Jan 20, 2008 | 02:37 PM
Tyson's Avatar
does it go in gear with the engine NOT running?
Old Jan 20, 2008 | 02:38 PM
Tyson's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by andrey320 &raquo;</TD></TR><TR><TD CLASS="quote"> The lever that the cable is connected to does not seem to go up. </TD></TR></TABLE>
oh, nevermind. seems like you just need a new cable.
Old Jan 20, 2008 | 02:45 PM
Targa250R's Avatar
be professional
Default Re: transmission will not go into gear ??? (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">t just means its time to replace my clutch. not something im looking forward too either.</TD></TR></TABLE>
It's not so bad. Be glad you're on the left coast where the bolts don't rust
Old Jan 20, 2008 | 02:46 PM
Tyson's Avatar
Default Re: transmission will not go into gear ??? (Targa250R)
its not like i havent done it half a dozen times before. im just lazy.
Old Jan 20, 2008 | 02:53 PM
Targa250R's Avatar
be professional
Stop posting on Honda-Tech and start filling up the air compresser
Old Jan 20, 2008 | 03:22 PM
andrey320's Avatar
Tyson, it does go into gear with the car off. The cable pulls, but the bracket does not move up (by hand either).
Modified by andrey320 at 6:01 PM 1/20/2008
Old Jan 20, 2008 | 03:55 PM
eda6's Avatar
time to drop the tranny. here's my thoughts.... release bearing is having a problem sliding (possibly no lube or it's getting hung up somehow on the shaft) or perhaps there's some rust between your case and release arm shaft and it seized. now if the release sytem checks out good then it's a clutch problem.
Old Jan 21, 2008 | 06:22 AM
pauley01's Avatar
Default Re: (eda6)
I agree with the guy above. I was having the exact same problem as Tyson. I could not get my car in gear. I would sit at a stop light and could not get into first. I dropped the tranny and the spring that controls the throwout bearing was broken. I had a NIGHTMARE with replacing this too. The one bolt that holds the spring/fork and shift lever together was broken. I had to drill it out to get to the spring. After 3 days of hard work, and a few "mods", I had a new rear main seal, clutch and properly working throwout bearing. It works great now.
2000Accord5sp
Dec 11, 2008 10:39 AM
1320king
13
Apr 19, 2008 12:33 PM
speedfreek128
10
Mar 28, 2008 07:45 PM
ThaMatrix
Jun 7, 2005 03:15 PM
Kato7997
Feb 3, 2003 04:39 PM
