Half Shaft...quick question
Are all B series half shaft the same? I have a small hole in outter rubber CV boot and it throws grease all over the inside of my whel and looking to get a new one.
TIA
TIA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by instrument »</TD></TR><TR><TD CLASS="quote">yes, unless its a b18c5
boooyaaaa?</TD></TR></TABLE>
whats different about the b18c5 axles ? They are the same, the only difference is with the 98 spec JDM type r's that have the 36mm axles and thats on the hub side.
OP...you can use any axle from a manual tranny 94-01 teg
94-97 del sol DOHC vtec
99-00 si
if your care has abs you will need an abs axle, if it doesn't you can use abs or non abs axles
gl
99-00 si
gl
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stevenk »</TD></TR><TR><TD CLASS="quote"> the auto halfshaft does not fit the manual.</TD></TR></TABLE>
thanks captain obvious.
get any b series axle from 94-01 integra or 99-00 si and youll be just fine.
