when its WOT the motor shuts down???? HELP!!!
Old Jan 20, 2008 | 11:11 AM
DEL HATCH's Avatar
Default when its WOT the motor shuts down???? HELP!!!
i searched last night for some info, found similar topics, but alot of them didnt have the solution once it was fixed..
at 1/2 or 3/4 throttle, the motor is fine. drives fine, hits vtec, no problems
motor is a 95 gsr-completely stock
once its at WOT, no matter what RPM it shuts down- doesnt shut off, doesnt gain/lose power, totally shuts down and does nothing..
i changed my head gasket and put a new throttle body on, and since then its been doing this..
***********IM NOT THROWING ANY CEL'S**********
this is what ive done so far to try and correct it:
changed spark plugs
changed spark plug wires
changed dizzy rotor
checked timing 4 different times
ive checked my vacuum lines, dont see anything wrong or not hooked up
please help.. anything you can think of
Old Jan 20, 2008 | 02:35 PM
tealegg's Avatar
Default Re: when its WOT the motor shuts down???? HELP!!! (DEL HATCH)
check the TPS and the wires to it. my old crx had the same problem.
Old Jan 20, 2008 | 03:33 PM
DEL HATCH's Avatar
Default Re: when its WOT the motor shuts down???? HELP!!! (tealegg)
thanks, i will check all the voltages and make sure its working..
anything else just incase??
Old Jan 20, 2008 | 06:17 PM
jkeno112's Avatar
check the TPS sensor and maybe the wires. A couple of dyno sessions i had the car shut off on WOT and it was because the TPS wires were flipped around.
Old Jan 20, 2008 | 06:46 PM
DEL HATCH's Avatar
Default Re: when its WOT the motor shuts down???? HELP!!! (jkeno112)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jkeno112 &raquo;</TD></TR><TR><TD CLASS="quote">check the TPS sensor and maybe the wires. A couple of dyno sessions i had the car shut off on WOT and it was because the TPS wires were flipped around. </TD></TR></TABLE>
wouldnt i throw a CEL if it was the TPS? ill check regardless, but shouldnt it throw a code?
Old Jan 28, 2008 | 04:41 PM
DEL HATCH's Avatar
it was the TPS sensor.. i just never figured it could be since it didnt throw a code.. the green and yellow wires were switched around-switched them back and now everything is fine.. thanks for all the help guys!!
Coltmorris
Jul 13, 2009 11:32 AM
DEL HATCH
Jan 28, 2008 04:59 PM
DEL HATCH
Jan 28, 2008 04:42 PM
scrEaMO Kyle
Jan 25, 2005 07:55 AM
user 996328629
Jun 9, 2003 07:18 PM
