Thread pitch and size of a b16 header to block bolt?
Old Jan 20, 2008 | 09:33 AM
importdreamer's Avatar
Default Thread pitch and size of a b16 header to block bolt?
Once this -2 degrees **** goes away I'm replacing my header and cat back. The header I purchased was junk (zr1?), and the header holes didn't line up on the last one. We left the bolt out and I was sure to put it somewhere safe for when I replaced it at a later date. Now I have forgot where that safe place was. It's no longer a stud in there it was an actual bolt. I think the previous owner pulled them out and replaced them all when the first header was put on. Either way I figured I might stock up on some of the **** while it's cold so I can do all the replacements with out running around the day it all comes in. The car is an em1.
Old Jan 20, 2008 | 09:56 AM
Chiovnidca's Avatar
Default Re: Thread pitch and size of a b16 header to block bolt? (importdreamer)
You mean the studs on the cylinder head? They're 8x1.25
Old Jan 20, 2008 | 10:07 AM
Default Re: Thread pitch and size of a b16 header to block bolt? (Chiovnidca)
yeah is it fine thread pitch or extra fine?
Old Jan 20, 2008 | 01:09 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by importdreamer &raquo;</TD></TR><TR><TD CLASS="quote">yeah is it fine thread pitch or extra fine?</TD></TR></TABLE>
1.25
Old Jan 20, 2008 | 01:45 PM
IN VTEC's Avatar
It would be considered fine thread. Coarse thread is a 1.50 thread pitch. Extra fine would be 1.00.
Old Jan 20, 2008 | 01:47 PM
HondamanXxX's Avatar
GO GIANTS!
Default Re: Thread pitch and size of a b16 header to block bolt? (IN VTEC)
Answer might be in this thread https://honda-tech.com/zerothread/1885652
Old Jan 20, 2008 | 01:57 PM
IN VTEC's Avatar
The previous owner didn't pull them out. After a certain year, they remove 8 out of 10 of the stud and nut combinations and used flange bolts in their place. It was probably save money in terms of materials and manufacturing time.
People_Mover
Jun 3, 2004 07:44 PM
ebelp
Jul 29, 2003 10:21 AM
EF_LSVtec
Oct 3, 2002 06:30 AM
