Toda A Cams Idle Video
Old Jul 1, 2002 | 12:00 PM
nsx-Animal's Avatar
Default Toda A Cams Idle Video
Here is a Video off my car with Toda A cams. Pretty quite
http://200.62.5.11/Idle-Engine.mpg
Old Jul 1, 2002 | 12:06 PM
MPH's Avatar
MPH
New User
Default Re: Toda A Cams Idle Video (Itr-Animal)
How much power are you making?
Old Jul 1, 2002 | 12:09 PM
nsx-Animal's Avatar
I haven't Tuned it yet, but I am guessing with all my mods I should get somewhere in the 190 range.
Old Jul 1, 2002 | 12:36 PM
Black R's Avatar
25 Year Member
.....that video looks like you are idling with the fans, ac, radio, and headlights on. 1200 rpms?
Old Jul 1, 2002 | 12:45 PM
nsx-Animal's Avatar
Default Re: Toda A Cams Idle Video (Black R)
Nope.. no AC, or Lights.
Old Jul 1, 2002 | 12:58 PM
TodaSi's Avatar
Yep, stock idle with Toda A cams.
BTW, your ground wire is in the wrong place.
Old Jul 1, 2002 | 01:21 PM
underrated99si's Avatar
Default Re: Toda A Cams Idle Video (TodaSi)
Sounds good nowhere as noticable as the B's lump lump reminds me of JUN cams nice and stock like. Now get her tuned and lets see what she puts out
Old Jul 1, 2002 | 01:24 PM
shamoo's Avatar
Will you make something up for me please?
How come I have seen several people who've said this when the first picture (left) is the stock grounding location?
Old Jul 1, 2002 | 01:28 PM
AssPenny's Avatar
Default Re: Toda A Cams Idle Video (shamoo)
Cause they are wrong. Think about it. The location of the ground while on the first picture (left) is to the valve cover only. Now the valve cover is sitting on a rubber gasket, and all the bolts have a rubber gaskets so its not grounded. When you do it liek the second picture (right) it is grounded to the bolt that goes into the head.
Craig - Who still thinks it does not make a big enough difference in either location.
[Modified by AssPenny, 5:29 PM 7/1/2002]
Old Jul 1, 2002 | 01:40 PM
nsx-Animal's Avatar
Default Re: Toda A Cams Idle Video (AssPenny)
This is just in case you you get hit by lightning
Old Jul 1, 2002 | 01:41 PM
01PYITR's Avatar
"Craig - Who still thinks it does not make a big enough difference in either location."
I agree with you Craig, the head and block are made out of aluminum... not a good conductor
Edit: Do you have OIL in that motor or is it the video sound???
[Modified by 01PYITR, 5:51 PM 7/1/2002]
Old Jul 8, 2002 | 01:07 AM
sparkz's Avatar
in the second picture, how can it be the "jdm throttle cable bracket" when its in frotn of the motor? doesnt the cable lay behind the motor?
Old Jul 8, 2002 | 03:18 AM
kenji's Avatar
25 Year Member
Default Re: Toda A Cams Idle Video (sparkz)
That is a JDM throttle cable bracket. As we all know, JDM cars are RHD. Therefore the throttle cable is on the other side of the car. This makes routing the throttle cable different when compared to LHD cars. With a RHD drive Civic/Integra the the cable goes around the front of the car, up the passenger side (RHD passenger side) and to the TB.
Also, with regards to the topic of this post, Toda A cams are supposed to idle like stock cams. The primary and secondary lobes are nearly identical to the stock cam profile(s).
-kenji
[Modified by kenji, 4:20 AM 7/8/2002]
LilCivic04
24
Jun 23, 2008 06:15 AM
93solsigsr
Apr 29, 2003 06:34 PM
B18CXr
Aug 29, 2002 05:34 PM
Austin
Mar 9, 2002 10:43 PM
GSRacer
Oct 3, 2001 11:22 AM
