JG dvs with Skunk2 s2 or Pro1
Old Jan 20, 2008 | 08:21 AM
litovi3tboi503's Avatar
Default JG dvs with Skunk2 s2 or Pro1
For spring time I really want to upgrade to some other cams with more beef. But my current set up is with JG dual valve springs and Ti retainers. I couldnt find anything about JG's spring rate. So I am wondering if it will be okay running s2s2 or the pro1's with my current set up. If I do use this set up how long will the springs last.
Any info will help guys. And again I did do search but came up with nothing about these springs.
Old Jan 20, 2008 | 05:30 PM
Pro-Am 1934's Avatar
Default Re: JG dvs with Skunk2 s2 or Pro1 (litovi3tboi503)
If I remember correctly the JG valve train is by REV.
Jason
Old Jan 20, 2008 | 06:04 PM
Default Re: JG dvs with Skunk2 s2 or Pro1 (Pro-Am 1934)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pro-Am 1934 &raquo;</TD></TR><TR><TD CLASS="quote">If I remember correctly the JG valve train is by REV.
Jason</TD></TR></TABLE>
Hmm if thats so then. The rev dvs is softer at open pressure compare to the skunk2 pro. But more stiff at seated pressure.
Skunk2 Pro -B series Vtec- 311-05-5350
60lbs seated at 1.320 or 33.5mm
210 lbs @ .820 " - 20.828mm
bind @ .720 " 18.288mm
REV- UR8101s
80lbs seated at 34mm
195 @ 10mm
coil bind 19mm
max net lift 12.5 mm
REV UR 8110S
70lbs @ 34 mm lift
170 @ 10 mm
coil bind 19mm
max net lift 13.5 mm
tofast4uh22
Apr 29, 2014 06:11 PM
Muckman
Feb 24, 2012 10:43 AM
Cyber ITR
Jul 23, 2009 03:47 PM
vtec4max
Jul 28, 2007 08:49 PM
civic2slo
Oct 6, 2004 11:06 PM
