b16a oil pump compatibility
Old Jan 20, 2008 | 08:17 AM
packman5280's Avatar
Default b16a oil pump compatibility
I have a 92-95 JDM b16a that i am putting into my 2000 si which spun a rod bearing. my b16a2 oil pump has a sensor on the outside of it, and a star like ring right behind the timing pulley. the JDM b16a does not have this. will swaping the oil pump be pretty straight forward? I need to keep that sensor and the oil pumps are slightly different shape to acomodate it. I can't just move the sensor over, so the whole pump has to go. please tell me the crank is the same and the pump will just slide on. Thanks in advance for any help.
Old Jan 20, 2008 | 09:44 AM
dr.garagetuner's Avatar
Default Re: b16a oil pump compatibility (packman5280)
yes they are the same oil pumps. And the sensor you are speaking of is the knock sensor.
Old Jan 20, 2008 | 09:57 AM
cool thanks. i just ordered the gasket set with the main seal, oil pan, oil pick up, and o rings, got the right stuff for the pump itself, should be good to go. thanks, that is good to hear the pump will fit, i was a little worried.
that's the knock sensor way down there? it looks like it's reading that star like ring, because it is pointing right at it.
Old Jan 20, 2008 | 09:59 AM
BryanM.'s Avatar
Resident Gearhead
Default Re: b16a oil pump compatibility (dr.garagetuner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr.garagetuner &raquo;</TD></TR><TR><TD CLASS="quote">yes they are the same oil pumps. And the sensor you are speaking of is the knock sensor. </TD></TR></TABLE>
Yes they are compatable, but no that's not a knock sensor, it's a Crank Position Sensor.
Old Jan 20, 2008 | 07:06 PM
Default Re: b16a oil pump compatibility (mcvtec)
pardon my mis information my brain took a huge sh*t it is the CPS i dont know why i thought that. But thanks for clearing that up.
potatointegra01
Feb 2, 2016 04:23 PM
existanzcivicb20
Mar 16, 2006 04:28 AM
warwagon
Jan 11, 2005 05:14 PM
