** ITR Help please !!
Old Jan 20, 2008 | 07:10 AM
JM_Vtec's Avatar
Default ** ITR Help please !!
Hey guys my buddy bought an itr about a month ago and we just cannot figure out what in the hell can be wrong with it .. The information that i know is that it is a 2000 Itr that had been theft recovered and put back together !! The engine has around 85,000 miles on it and it has i/h/e and tuned on Pharebal.net (sp) ecu .. For some reason it starts to cut out and sputter at around 6500 and up and struggles and i do mean struggles to get to redline, but for some reason every once in awhile and it could be weeks but it'll pull hard all the way to redline. We've replaced the plugs, plug wires, distributor , cap, rotor, new fuel pump, new fuel filter, and checked timing. We are totally stumped on what it could be !! any help would be appreciated ... and if you have any questions about details just ask !! thanx
Old Jan 20, 2008 | 08:01 AM
espanol's Avatar
Default Re: ** ITR Help please !! (JM_Vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JM_Vtec &raquo;</TD></TR><TR><TD CLASS="quote">Hey guys my buddy bought an itr about a month ago and we just cannot figure out what in the hell can be wrong with it .. The information that i know is that it is a 2000 Itr that had been theft recovered and put back together !! The engine has around 85,000 miles on it and it has i/h/e and tuned on Pharebal.net (sp) ecu .. For some reason it starts to cut out and sputter at around 6500 and up and struggles and i do mean struggles to get to redline, but for some reason every once in awhile and it could be weeks but it'll pull hard all the way to redline. We've replaced the plugs, plug wires, distributor , cap, rotor, new fuel pump, new fuel filter, and checked timing. We are totally stumped on what it could be !! any help would be appreciated ... and if you have any questions about details just ask !! thanx </TD></TR></TABLE>
Put in a good ecu. It sounds like the tune on your ecu is junk.
Old Jan 20, 2008 | 08:20 AM
Comp97GSR's Avatar
Default Re: ** ITR Help please !! (espanol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by espanol &raquo;</TD></TR><TR><TD CLASS="quote">
Put in a good ecu. It sounds like the tune on your ecu is junk.</TD></TR></TABLE>
That or an ignition issue. Try another known good ECU and report back.
Old Jan 20, 2008 | 08:23 AM
JM_Vtec's Avatar
Default Re: ** ITR Help please !! (Comp97GSR)
Alright thanx guys !! we'll try it out today or tomorrow and see what we can come up with ... also what should we try if its ignition ??
Old Jan 20, 2008 | 08:27 AM
Comp97GSR's Avatar
Let do 1 thing at a time. I would almost bet that it is the ECU. Sounds almost like what somebody I know went through with his R.
Old Jan 20, 2008 | 01:29 PM
JM_Vtec's Avatar
Alright guys ... bad news !! we plugged in the org. ecu and it actually ran a lil worse .. as soon as it would he vtec it pretty much falls on its face, sputtering and cutting out !! could it be Vtec solenoid ?
Old Jan 20, 2008 | 02:50 PM
espanol's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JM_Vtec &raquo;</TD></TR><TR><TD CLASS="quote">Alright guys ... bad news !! we plugged in the org. ecu and it actually ran a lil worse .. as soon as it would he vtec it pretty much falls on its face, sputtering and cutting out !! could it be Vtec solenoid ? </TD></TR></TABLE>
Is it throwing any codes?
Old Jan 20, 2008 | 05:22 PM
migs's Avatar
It sounds like a distributor issue. Did you replace the distributor or distributor cap? I would look at your ignition coil of all things.
Old Jan 20, 2008 | 09:04 PM
JM_Vtec's Avatar
Default Re: ** ITR Help please !! (migs)
yea its throwing an iacv code ... but thats it !! :-(
And we put a new distributor on also cap and rotor but we'll go back over and check all the ignition components and make sure everything is grounded and on right !!
Any other ideas !?
Old Jan 21, 2008 | 06:13 AM
JM_Vtec's Avatar
could a bad grounding somewhere do that ??
Old Jan 21, 2008 | 09:59 AM
HarfordCTR's Avatar
I had a problem with my secondary oxygen sensor grounding out and causing similar symptoms. Check them both
Old Jan 21, 2008 | 01:47 PM
Parada's Avatar
Default Re: ** ITR Help please !! (HarfordCTR)
far shot in the dark, but make sure the battery's strapped down tight and not arcing against the firewall, i have a nice little hole where the positive terminal bounced off my firewall.
*edit* my bad, i thought it was running good most of the time and only sputtering once and a while. ill read slower next time.
Old Jan 21, 2008 | 07:32 PM
JM_Vtec's Avatar
Default Re: ** ITR Help please !! (Parada)
well the only thing about the 02 sensor is he's running obd1 because of the tune :-( !!
Old Jan 21, 2008 | 07:36 PM
migs's Avatar
I thought you needed to run OBD2 02 sensors regardless of the tune or ECU?
Old Jan 21, 2008 | 07:49 PM
JM_Vtec's Avatar
you do have to run obd2 o2 sensors but you only have to run 1 of them ... and he said he was having probs with his secondary o2 sensor (aka your second o2 sensor) which you dont need when running obd1 tuned ecu ..
Old Jan 22, 2008 | 08:17 AM
JM_Vtec's Avatar
any other ideas ?? the closest repitable shop is 2 hours away
Old Jan 24, 2008 | 05:05 AM
JM_Vtec's Avatar
lil update : still cant find the problem but for some reason injectors have been going out so replaced them with brand new ones and one went out already !?! does that help any guys ??
Old Jan 24, 2008 | 10:49 AM
JM_Vtec's Avatar
lunch bump
Old Jan 24, 2008 | 04:16 PM
brokenCRX's Avatar
Being a theft recovery, how are the wire harnesses? Were they cut by the thieves? If so were they repaired (soldered) or replaced?
Old Jan 24, 2008 | 06:57 PM
JM_Vtec's Avatar
Default Re: ** ITR Help please !! (brokenCRX)
they put a new harness in there ;-( !!! but since it was sitting for awhile could rust be in the tank or lines and cause it to run like crap and kill injectors ??
itrpwr
Aug 27, 2004 03:10 PM
Kyle244R948
Jun 10, 2004 06:02 AM
Jowee
Nov 11, 2003 04:06 PM
