Power steering in EE9
Old Jan 20, 2008 | 04:24 AM
Nippo's Avatar
Default Power steering in EE9
Hi, I'm Nippo from Italy
Now I use the Advan 048 for daily driving and the parking is really hard without PS
and the steering ratio is 4.1
Can I fit the ITR steering rack with PS ?
Thanks a lot
Old Jan 20, 2008 | 07:51 AM
Crx Jimmy's Avatar
Default Re: Power steering in EE9 (Nippo)
I beleive you have more options over these I have seen mor models come with power steering in europe. Here only the automatic civic hatch's came with power steering, All you would need is the power steering rack along with the rear crossmember that the rack bolts to, and all the lines and power steering resevoir and the pump. If you have a b16 in your car you can use all the civic stuff except the pump. you can source the pump off of any integra. if you use a 90-93 integra pump the lines have to go throught the contraption by the vss to proportion the fluid, if you use a 94 up pump you dont need that. Also you will need a crank pulley with a ps belt groove
AntraxL1
Honda Civic (2001 - 2005)
Aug 24, 2014 10:01 AM
Black R
Nov 8, 2012 12:30 PM
old 2nr
Jul 29, 2006 10:40 AM
ibme_uk
Jan 6, 2005 08:23 AM
UncleBen'sRacing
19
Feb 3, 2003 11:10 PM
