3rd popped tire in less then a year!
Old Jan 19, 2008 | 10:48 PM
EpicKills's Avatar
Banned
Default 3rd popped tire in less then a year!
I haven't even owned my 94 integra for a year and I've replaced the front tires once because of a flat. Ran over a nail, patched it, and tonight got another flat. I've checked my tires, all have a lot of tred left except the one that went flat tonight. The one that went flat tonight looks expletiveed up. Hardly any tred at all, it looks like someone has been scrapping curbs with it, white marks all along the SIDE of the tire. Intrestingly enough, thats my front left tire. So I don't even park on that side of the car. So WTF?! Does anyone have any clue about rims wearing tires down hardcore? Because I just got these replaced and I just got my car back from pacc a few weeks ago and they themselves said My breaks and tires have a while to go. I'm so confused!
I'm about to throw the money i have saved for my security system and gps and hood pins into new 15 in rims and tires instead of these 17 in mexican nightmares!
Old Jan 20, 2008 | 08:31 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: 3rd popped tire in less then a year! (EpicKills)
Is it possible there is a suspension problem with your car (bent tie rod, shot bushings, that sort of thing)? That can cause a tire to wear out unusually fast. If it is really drastic, it could cause it to scrape against the wheel well causing marks on it. I would put it up on a lift and check it (or have an experienced mechanic do it). Bad alignment is another possible cause of problems. Also, have you been checking your tire pressure from time to time? If the pressure is way off, it's possible for the sidewall to be collapsed and cause problems.
Old Jan 20, 2008 | 03:17 PM
2ndlife's Avatar
Default Re: 3rd popped tire in less then a year! (nsxtasy)
^+1.
I had similar symptoms before and it was my suspension that caused it.
Old Jan 20, 2008 | 04:13 PM
EpicKills's Avatar
Banned
The skid plate under my front bumper had one end hanging off due to no bolt. I'm guessing it was this.
Old Jan 20, 2008 | 11:19 PM
old man neri's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EpicKills &raquo;</TD></TR><TR><TD CLASS="quote">The skid plate under my front bumper had one end hanging off due to no bolt. I'm guessing it was this.</TD></TR></TABLE>
Are you talking about a piece of plastic rubbing against your tire?
r1lsr
Mar 20, 2009 02:34 PM
xaznx
Jun 27, 2003 08:35 PM
CanadaRed
Apr 23, 2003 03:14 PM
SIXTYdashONE
Jan 29, 2003 04:05 PM
Type R 702
Jun 14, 2002 10:33 AM
