Blox front camber kit
Old Jan 19, 2008 | 09:03 PM
IronShogun's Avatar
Default Blox front camber kit
Wondering if anyone with the 94-01 Blox front camber kit had to roll the fenders on a 93 Civic coupe to install it. Also does any aftermarket strut fit with no problems after installation?
Old Jan 19, 2008 | 09:29 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Default Re: Blox front camber kit (IronShogun)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IronShogun &raquo;</TD></TR><TR><TD CLASS="quote">Wondering if anyone with the 94-01 Blox front camber kit had to roll the fenders on a 93 Civic coupe to install it. Also does any aftermarket strut fit with no problems after installation?
You may have to roll the fenders depending on how little negative camber you want, how wide your wheels are, wheel offset, tire size, and how low the car is.
Yes...any aftermarket struts should fit. The camber kit just mimics the stock control arm, but usually has slots to move the ball joint in and out. People do have problems with the ball joint adjustment nuts hitting the strut tower, though.
If you align for toe, you will have minimal wear. Camber doesn't really wear tires. Unless you're drag racing or doing burn outs.
Old Jan 19, 2008 | 10:05 PM
IronShogun's Avatar
Default Re: Blox front camber kit (B serious)
damn good looks on the info.
xla301
Apr 4, 2005 11:58 PM
Sandor
Nov 17, 2003 09:01 AM
joey1320
Nov 13, 2003 04:16 PM
AcCorD 9dfive
Aug 17, 2003 05:53 PM
jdmCivic925
Aug 13, 2003 10:03 AM
