Which tranny best for B18C5?
Old Jan 19, 2008 | 02:39 PM
CroSi's Avatar
Default Which tranny best for B18C5?
I have searched but did not find any useful information.
I am swapping a C5 into an EF and wondering which CABLE tranny would be the best mated to this engine? I like the ratios of the LS tranny and they are cheap.
Any thoughtful input?
Thanks again.
Old Jan 19, 2008 | 02:45 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: Which tranny best for B18C5? (CroSi)
best, use the hyrdo convert kit and use it's tranny.
Really, there is no best, it depends what you are doing with it, if you like an LS ratio... well umm ok..
Old Jan 19, 2008 | 02:48 PM
ryan_crx's Avatar
https://honda-tech.com/zerothread/1847132
did you look in the ► The Official "Where can I buy a engine/tranny/parts for my CRX/Civic!! ►
cuz if toad see this he will tell you to search
thats what he has told me like 3 times and he will lock it
CroSi's Avatar
Sorry I forgot to mention that the car will be mostly set up for Auto X and the occasional drag race.
Old Jan 19, 2008 | 02:51 PM
Ass$nyper's Avatar
Default Re: (CroSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CroSi &raquo;</TD></TR><TR><TD CLASS="quote">Sorry I forgot to mention that the car will be mostly set up for Auto X and the occasional drag race.</TD></TR></TABLE> Then even more reason to want to convert the c5s tranny agressive gears and stock LSD.
if you want to use a cable tranny a b16 one will be great, y1 if you can
Old Jan 19, 2008 | 03:07 PM
StorminMatt's Avatar
Default Re: (***$nyper)
If you want a cable transmission, the B16A S1 is probably the best. It has exactly the same gear ratios as the 1996-1998 JDM and all USDM ITR transmissions. Another possibility would be the YS1 from the 1992-1993 Integra. This transmission is actually slightly shorter than the S1. So acceleration should be slightly better. But freeway revs will be a little higher. As for the LS transmission, this really isn't the best choice, as the engine will fall below VTEC on shifts. But if you like the gearing, then you could try one. After all, they are pretty cheap these days. Of course, the other optin would be to swap the LS fifth gear into a VTEC transmission.
Old Jan 19, 2008 | 05:54 PM
Crx Jimmy's Avatar
Default Re: (StorminMatt)
If you are dead set on a cable box, use a ys1 case and put the itr internals in it, thats what I rock
Old Jan 19, 2008 | 05:57 PM
CRX Toad's Avatar
Default Re: (CroSi)
That is going to be super hard to setup a car for both of those.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">use a ys1 case and put the itr internals in it, thats what I rock</TD></TR></TABLE>
I'd go hydro is you haven't bought a trans yet.
Old Jan 19, 2008 | 06:06 PM
CroSi's Avatar
Default Re: (CRX Toad)
Haha stupd of me to even say the car will be used for auto x AND drag. Not thinking.
I think I'll be going with a B16 tranny, and throw in an OBX lsd in there or find a stock LSD tranny.
I appreciate the help, cheers.
Old Jan 19, 2008 | 06:09 PM
CRX Toad's Avatar
Default Re: (CroSi)
DON'T GO OBX YOU WILL BE SORRY
Old Jan 19, 2008 | 06:12 PM
CroSi's Avatar
I only hear good things about them up here in Canada....
99lsvtecauto
Oct 30, 2003 09:22 AM
92KillerBee
Sep 21, 2003 08:27 AM
JDM CTR EK
Jul 21, 2003 05:24 PM
skellator_thoj
Apr 9, 2003 10:04 AM
