Are all 92-95 civic injectors the same?
I am switching from turbo back to normal. I need to get stock injectors back in my car. I have a D16A(D16z6) are the injectors off 92-95 civics cx, dx, lx, vx, ex, or si models the same CC and will work properly? Thanks.
I don't think they're all the same, but I have stock injectors from my d16y8 you can have if you want. I just turbod my car less than 2 mos. ago
i don't think it will fit my car. mine is obd1, your d16y8 is obd2. and plus, i am in california, you're in washington is it? unless you do not mind shipping it to me for free
haha. thanks any ways.
no all civic injectors are 240cc and yes obd2 injectors will work as long as he uses the clips from the obd2, i am currently running obd2 civic injectors in my 92 hatch, i just soldered on the new tails. they are both saturated and 240cc injectors. only h22 injectors are 310cc and type r is 290cc
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doood »</TD></TR><TR><TD CLASS="quote">type r injectors are also 240cc. all d and b series injectors are 240cc. only h22 injectors are bigger.</TD></TR></TABLE>
Success!
Success!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted92hatch »</TD></TR><TR><TD CLASS="quote">no all civic injectors are 240cc and yes obd2 injectors will work as long as he uses the clips from the obd2, i am currently running obd2 civic injectors in my 92 hatch, i just soldered on the new tails. they are both saturated and 240cc injectors. only h22 injectors are 310cc and type r is 290cc</TD></TR></TABLE>
im not sure about the the actual cc of the injectors but i know that those injectors are in fact different
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lv6l »</TD></TR><TR><TD CLASS="quote">I am switching from turbo back to normal. I need to get stock injectors back in my car. I have a D16A(D16z6) are the injectors off 92-95 civics cx, dx, lx, vx, ex, or si models the same CC and will work properly? Thanks.</TD></TR></TABLE>
I can tell you for sure that the '92-'95 LX, EX, Si, and DX all have the same injectors (240cc). I'm pretty sure that the CX and VX do too, though I am not positive. Though seeing as how the ones I listed above are the most common, you shouldn't be "only finding" CX/VX ones anyway, but even if you were, I'm pretty sure they're 240cc also.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MiMiK »</TD></TR><TR><TD CLASS="quote">all 92-00 civic injectors are 240cc except for the ones that comes on the d16y7. those are 190cc.</TD></TR></TABLE>
Im pretty sure the civic gx uses different injectors as well considering its natural gas
[QUOTE=Syndacate]
the only difference is the plugs, saturated 240cc injectors are saturated 240cc injectors
[QUOTE=Syndacate]
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hmtcrxsir »</TD></TR><TR><TD CLASS="quote">only the VTEC model prelude is 310cc because of the bigger displacement</TD></TR></TABLE>
Awesome, "civic != prelude" - look at that for awhile
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted92hatch »</TD></TR><TR><TD CLASS="quote">im not sure about the the actual cc of the injectors but i know that those injectors are in fact different
[QUOTE=Syndacate]
the only difference is the plugs, saturated 240cc injectors are saturated 240cc injectors</TD></TR></TABLE>
Looks like you were trying to quote me - on something I didn't say - and messed up?
The DX/LX/EX/Si injectors from '92-'95 are all the same - 240cc Honda OEM OBD-I injectors. That's all I said, I said I don't know about the CX and VX.
[QUOTE=Syndacate]
Here are some flow rate charts for injectors:
http://www.robietherobot.com/s...e.htm
http://go.mrgasket.com/pdf/dfi.pdf
And a good Chart:
And a good Chart:
jonesEK
Dec 17, 2010 07:27 AM
hbcivicman
Dec 1, 2005 05:20 AM
