Which Strut/Shock for Eibach Pro-Kit?
Old Jan 19, 2008 | 02:05 PM
96WhiteOnBlack's Avatar
Default Which Strut/Shock for Eibach Pro-Kit?
I have a 96 LS and I have a Pro-Kit. Im looking for performance and comfort. Im on a tight budget. I've looked at the Skunk2 Sports and I like those. What else would you guys suggest? And would you suggest the Skunk2 at all?
Old Jan 21, 2008 | 07:10 AM
Default Re: Which Strut/Shock for Eibach Pro-Kit? (96WhiteOnBlack)
Bump
Old Jan 21, 2008 | 07:16 AM
Micha's Avatar
FAILWGN
I think the KYB AGX's work good with those.
What is your budget?
Old Jan 21, 2008 | 07:28 AM
Default Re: Which Strut/Shock for Eibach Pro-Kit? (micha)
Bout $300 Shipped. Unless I run across a good deal. Then I would spring for a little more.
Old Jan 21, 2008 | 11:18 AM
XslickwhitetegX's Avatar
KYB and Eibach prokit is a nice set up I had it on my car for about 2months b4 I got sick of the stance and bought Koni and GC.. but it rode very nice and kyb shocks are adjustable so thats a +
they were a great combo it's just I wanted to lower more.. but I knew that when I bought them..lol it was just a quick fix for me.
Old Jan 21, 2008 | 11:22 AM
Default Re: Which Strut/Shock for Eibach Pro-Kit? (XslickwhitetegX)
Which KYBs did you have? And when you say it rode good... how good? As good as stock? Better? Worse? Thanks!
Old Jan 21, 2008 | 12:30 PM
oo9o9xaznoo's Avatar
I had tokico illuminas with the prokit. It was a nice ride on the lowest setting and an awesome ride with a high setting if you looking for a little bit of performance.
Old Jan 21, 2008 | 06:56 PM
Default Re: (oo9o9xaznoo)
You sellin the Tokicos? How many miles do they have on them?
Old Jan 21, 2008 | 09:09 PM
jomama's Avatar
personally, the pro-kit is nice, but it's not a low enough drop. typically, people see the back lowered more than the front. do your searching before you buy anything else
Old Jan 21, 2008 | 09:29 PM
SuckMyDOHC's Avatar
The pro-kit doesn't need anything spectacular, KYB GR-2's would be fine.
Old Jan 22, 2008 | 05:44 AM
Default Re: (SuckMyDOHC)
Thats true. All I really wanted it for was to get rid of most of the fender well gap. A small increase in handling is just a plus for me. After I got them I started thinking about my stock struts/shocks that are 12 years old and have almost 160k on them. I just dont think they could handle the ROUGH roads of Louisiana with a lower and stiffer spring.
Old Jan 22, 2008 | 06:04 AM
MeanGreenMachine's Avatar
Default Re: (96WhiteOnBlack)
what about eibach shocks?
Old Jan 22, 2008 | 07:04 AM
qazaq's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oo9o9xaznoo &raquo;</TD></TR><TR><TD CLASS="quote">I had tokico illuminas with the prokit. It was a nice ride on the lowest setting and an awesome ride with a high setting if you looking for a little bit of performance.</TD></TR></TABLE>
illuminas here too but with eibach sportline. im changing over to ground control coil springs tho since the ride looks uneven with just lowering springs
Old Jan 22, 2008 | 09:37 AM
Default Re: (qazaq)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96WhiteOnBlack &raquo;</TD></TR><TR><TD CLASS="quote">
Which KYBs did you have? And when you say it rode good... how good? As good as stock? Better? Worse? Thanks! </TD></TR></TABLE>
I owned the AGX(adjustable shocks) yes they rode a lil better than stock depending on the setting you put them on...I've only had AGX and Koni to compare as shocks go, and the Koni ride a hell of a lot better than the AGX.. but AGX are good for a DD.. Pretty cheap adjustable shocks IMO
But tokico illuminas are a lil better shock for the money
Old Jan 22, 2008 | 10:14 AM
racebum's Avatar
Default Re: (XslickwhitetegX)
I think you can get the Tokico HP's for like $215 now, good way to go if you want to save money. If you turn the dollars up the Konis are something else, they really give you a great feel of the road and control body motion. The ride isn't punishing just tight. I've used the Koni sport on my Vette and a couple prior cars and have always been very pleased.
strtkart
Aug 27, 2007 09:59 PM
Xenon_Civic
Suspension & Brakes
Oct 13, 2006 10:29 AM
d16lxciv
Suspension & Brakes
Oct 9, 2006 08:37 AM
st95accord
Apr 30, 2005 12:53 AM
Blockhead G
Jan 10, 2002 02:55 PM
