LS/VTEC in crx help...
Old Jan 19, 2008 | 01:26 PM
ceyazzie's Avatar
Default LS/VTEC in crx help...
i just picked up a ls/vtec for my crx.. i need help. its a 90 HF.. i know everything needs changing. but need help on wiring and vacum hoses..
Old Jan 19, 2008 | 03:10 PM
crxfreak1117's Avatar
Default Re: LS/VTEC in crx help... (ceyazzie)
searching will bring u alot of info on this
use ur old wiring harness may need to get a dizzy adapter plug and ecu adapter if ur plannin on runnin obd1 if ur gonna use obd0 then get a pr3/pw0 ecu and you dont have to get and adapters only wiring u need to do is runnin wires to the ecu and to the vtec soleniod and oil pressure and a few more wires again searching will do alot of good and as far as the vaccumn diagram look on the bottom or ur hood if it is still there if not just search it
Old Jan 19, 2008 | 03:12 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: LS/VTEC in crx help... (crxfreak1117)
it's all in the FAQs and search.
I have a headache
Old Jan 19, 2008 | 04:11 PM
gursh d's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ceyazzie &raquo;</TD></TR><TR><TD CLASS="quote">i just picked up a ls/vtec for my crx.. i need help. its a 90 HF.. i know everything needs changing. but need help on wiring and vacum hoses..</TD></TR></TABLE>
Old Jan 19, 2008 | 05:40 PM
CRX Toad's Avatar
https://honda-tech.com/zerothread/1508680 check B16 threads
Old Jan 19, 2008 | 06:13 PM
vw eater's Avatar
sent pm
Old Jan 20, 2008 | 01:54 AM
ceyazzie's Avatar
Default Re: (vw eater)
i got a ECU from a del sol vtec.. that would work rite...
Old Jan 20, 2008 | 06:05 AM
gibsanez's Avatar
Default Re: (ceyazzie)
Until you get your ecu chipped and tuned, it'll work ok
Old Jan 20, 2008 | 06:17 AM
silver-crx-si's Avatar
very easy, what do you need help on. wiring is few wire. o2 sensor, vtec, and few more. make sure you get the screaming eagle ls vtec kit. that will make your vtec work proper.
Old Jan 20, 2008 | 06:19 AM
sikefcrx89's Avatar
Loved
Default Re: LS/VTEC in crx help... (silver-crx-si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silver-crx-si &raquo;</TD></TR><TR><TD CLASS="quote">very easy, what do you need help on. wiring is few wire. o2 sensor, vtec, and few more. make sure you get the GOLDEN eagle ls vtec kit. that will make your vtec work proper.</TD></TR></TABLE>
fixed
get wire jumper harness and distributor jumper harness the rest is a piece of cake
Old Jan 20, 2008 | 02:47 PM
ceyazzie's Avatar
Default Re: LS/VTEC in crx help... (sikefcrx89)
i bought it and it has a steal braided hose going from the oil pressure sender to the back of the head... above-where the coolent gose. is that ok r should i get the kit...
almostjdmeg
Dec 10, 2008 01:52 PM
Hybrido_90Civic
Apr 21, 2007 07:20 AM
C R X
Oct 11, 2003 10:37 AM
hybridDC4
Sep 25, 2003 06:30 PM
turbotime.
Apr 23, 2003 10:04 AM
