oxygen sensor!! question!!
Old Jan 19, 2008 | 12:53 PM
ALIKZANBRO's Avatar
Default oxygen sensor!! question!!
What happen if i don't have my oxygen sensor conected. the check engine is not on. could this affect the car? is it better for me to connected or leave it like that.. thanks
Old Jan 19, 2008 | 01:43 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: oxygen sensor!! question!! (ALIKZANBRO)
Does your check engine light work? (It should illuminate before you start the car.)
The oxygen sensor is critical to fuel economy, power, and engine durability.
Old Jan 19, 2008 | 02:01 PM
ALIKZANBRO's Avatar
Default Re: oxygen sensor!! question!! (Dogginator)
yes it is working. so that explains why it waist so much fuel. so i have to connect that right?
Old Jan 19, 2008 | 02:04 PM
Dogginator's Avatar
Daisy... Daisy...
Yes, it should be connected. I don't see how you are not throwing a CEL without it. What year is your car?
Old Jan 19, 2008 | 02:07 PM
ALIKZANBRO's Avatar
it a integra 90. also do i have to conected with the plug or can i just wire it up straight...
Old Jan 19, 2008 | 03:21 PM
Blahblah718293's Avatar
it would be alot easier to replace it with the plug, but theres no harm in connecting it directly.
make sure your check engine light works, meaning the bulb works, when you initially put your key in and turn it to "on" your light should come on.
and as the dog said, the o2 sensor is vital for engine performance, fuel economy, and emissions control. no signal from the o2 SHOULD throw a code, but since its a 1990, it may not.
Old Jan 19, 2008 | 04:44 PM
Dogginator's Avatar
Daisy... Daisy...
I prefer not to cut any wires on the car.
Old Jan 19, 2008 | 05:15 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">I prefer not to cut any wires on the car.</TD></TR></TABLE>
me too but if you dont have a connector, its your only choice, plus i think in 1990 theyre a 1 wire o2 sensor, so its pretty straightfoward.
on a misc note, does anyone know where i can get custom misc connectors, like for custom switches i put in my console, so when i take it out, its just a simple harness i can disconnect?
Old Jan 21, 2008 | 12:24 AM
ALIKZANBRO's Avatar
Default Re: oxygen sensor!! question!! (Blahblah718293)
thanks guys very helpful info i already connected straight cause like Blahblah718293 said is only one cable on my da 90 so it was very easy....
Old Jan 21, 2008 | 05:55 AM
GRAF-FITI's Avatar
* B A N N E D *
dogginator owned this thread
freshgear
Jan 1, 2013 06:15 PM
94EJ1Coupe
Mar 3, 2008 04:00 PM
92integraVTECgsr
Jan 21, 2008 07:48 AM
suprategrazx
May 21, 2007 07:26 AM
93WhiteHatch
May 31, 2005 07:21 PM
