obd1 cel ??
ok, well i have a obd1 b16a3 thats running on a p30 in my 99 civic ex.
i have a cel only when i let the engine run for a couple of minutes, but when i try to check it via the obd1 method (turn on, then turn off, repeat.) i cant get it to flash the cel, so should i check it using an obd2 diagnostic tool?
https://honda-tech.com/zerothread/1901557
You can check that out, If you dont already know what the service connector looks like,
