91 civic starting problem
Old Jan 19, 2008 | 10:09 AM
HondaEJ7's Avatar
Default 91 civic starting problem
hey all
Im in chicago, wheres it 0 degrees right now
i have a 91 civic sedan lx 5 speed
the car starts, but wont stay on. it only stays on when i keep the key turned.
i did some searches, and came to the conclusion that the ignitions electrical assembly has gone bad....correct me if i am wrong
Now, what part number from honda would that be/where can i get a replacement?
http://www.hondaautomotivepart...cgry5=
thanks
Old Jan 19, 2008 | 11:12 AM
HondaEJ7's Avatar
Default Re: 91 civic starting problem (HondaEJ7)
one
Old Jan 19, 2008 | 02:28 PM
Targa250R's Avatar
be professional
35130-SH5-505 SWITCH, STEERING $62.39
Old Jan 19, 2008 | 06:47 PM
HondaEJ7's Avatar
thanks :d
can you confirm that this is an ignition switch issue? or could it be a main relay?
Old Jan 19, 2008 | 06:51 PM
GSX 4G63T's Avatar
It also can be the ignition switch relay
Old Jan 19, 2008 | 07:02 PM
HondaEJ7's Avatar
so ill probably have to just check both
it had to happen on a cold *** weekend too
thanks man
Old Jan 19, 2008 | 07:06 PM
GSX 4G63T's Avatar
My dad's civic dx relay switch had corrosion buildup and the contacts were corroded like heck. Seemed like water got in, Because nearly half the relay box was filled with condensation.
Old Jan 19, 2008 | 07:09 PM
HondaEJ7's Avatar
hmm
this is all located right behind the lock cylinder under the steering right? the relay and switch?
and im wondering would a switch from a 97 civic work on a 91?
Old Jan 19, 2008 | 07:10 PM
GSX 4G63T's Avatar
Default Re: (HondaEJ7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaEJ7 &raquo;</TD></TR><TR><TD CLASS="quote">hmm
and im wondering would a switch from a 97 civic work on a 91?</TD></TR></TABLE>
look in hondapartsdeals.com and compare the part #.
Old Jan 19, 2008 | 07:13 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaEJ7 &raquo;</TD></TR><TR><TD CLASS="quote">and im wondering would a switch from a 97 civic work on a 91?</TD></TR></TABLE>
No.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">can you confirm that this is an ignition switch issue? or could it be a main relay?</TD></TR></TABLE>
Definitely sounds like the ignition switch based on what you described (mainly having to hold the key on). A bad main relay behaves differently (typically the car cranks but won't start in hot weather).
Old Jan 19, 2008 | 07:17 PM
HondaEJ7's Avatar
Alright well I might as well check both.
But yeah the car starts up like a champ, idles fine, everything is good.
I let go of the key and it dies instantly.
Old Jan 20, 2008 | 10:40 AM
HondaEJ7's Avatar
http://www.hondaautomotivepart...WITCH
is it part 008 in this diagram??
Old Jan 20, 2008 | 10:41 AM
GSX 4G63T's Avatar
Yep that's the switch. I had to replace my swtich because the previous owner splice it to power the radio.
Old Jan 20, 2008 | 10:42 AM
HondaEJ7's Avatar
Sweet thanks for the quick response bro.
And 2 day shipping is $37
I needed it tmrw, but I got tmrw covered with no car.
Thanks again. Install should be pretty straight forward though.
Old Jan 20, 2008 | 10:46 AM
GSX 4G63T's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaEJ7 &raquo;</TD></TR><TR><TD CLASS="quote">Sweet thanks for the quick response bro.
Thanks again. Install should be pretty straight forward though.</TD></TR></TABLE>
Not hard, remove the steering covers, then remove the bolts screws then unplug the harness and your done. Then install the new one
Old Jan 20, 2008 | 10:47 AM
HondaEJ7's Avatar
Yeah.
Cant believe it happened though. Old car.
Thanks a bunch bro. Im gonna order it now.
Old Jan 20, 2008 | 10:49 AM
GSX 4G63T's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaEJ7 &raquo;</TD></TR><TR><TD CLASS="quote">Yeah.
Thanks a bunch bro. Im gonna order it now.</TD></TR></TABLE>
Do a HOW TO thread? Many people have simliar problems with this
Old Jan 20, 2008 | 10:53 AM
HondaEJ7's Avatar
Yeah I don't mind.
I'll get the switch by Tuesday and shoot some pics while I do it.
Old Jan 20, 2008 | 11:01 AM
GSX 4G63T's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaEJ7 &raquo;</TD></TR><TR><TD CLASS="quote">Yeah I don't mind.
I'll get the switch by Tuesday and shoot some pics while I do it.</TD></TR></TABLE>
You will then recieve a
Old Jan 20, 2008 | 07:38 PM
HondaEJ7's Avatar
hahaha sounds good man.
Old Jan 20, 2008 | 07:40 PM
GSX 4G63T's Avatar
No seriously buddy, you will recieve a beer. I am not lying.
Old Jan 22, 2008 | 06:13 PM
HondaEJ7's Avatar
ill wait for the beer then hahahaha
and no part yet, monday holiday ftw.
i have to bum rides
Old Jan 27, 2008 | 10:28 AM
HondaEJ7's Avatar
finally had some damn time to try this, and its not f.uckin -25 outside
so i put in the new switch, and now the key doesnt go past a quarter turn, it feels like its locked.
also, even if the key isnt in the ignition, my radio turns stays on.
wtf?
Old Jan 27, 2008 | 12:48 PM
HondaEJ7's Avatar
bump
csk239
Nov 14, 2009 04:54 PM
hybrid1990crx
Feb 4, 2007 01:50 PM
wdtrnr2
Feb 28, 2006 03:50 AM
95_turbo
Mar 21, 2005 02:51 PM
Acswitz
Dec 28, 2004 06:12 PM
