f22b can i put a f23 crank in it
Old Jan 19, 2008 | 09:19 AM
low13da9's Avatar
Default f22b can i put a f23 crank in it
i want to stroke or what other cranks can i use i plan on running 15.1 compression pistons need help please
Old Jan 19, 2008 | 02:04 PM
gibsanez's Avatar
Default Re: f22b can i put a f23 crank in it (low13da9)
You running that engine on jet fuel?
Old Jan 19, 2008 | 03:58 PM
ESP.net's Avatar
Default Re: f22b can i put a f23 crank in it (gibsanez)
For all F and H series engines:
prior to 98, 90-97 as far as I know cranks are all 50 mm mains, 98-01 (F23A1) are 55 mm mains so to answer that no wont work... unless you have a 98-01 block to put it in.
Old Jan 20, 2008 | 07:42 AM
Lubo_25's Avatar
you can make it fit but you would need to machine the tunnel bores out precisely while maintaining the crankshaft centreline...with that type of compression i wouldnt stroke it too much the f22 crank should be fine for your power needs but to each their own
Old Jan 20, 2008 | 03:27 PM
thehatchninja's Avatar
Have you already decided on the bore? If I were you I'd just run an 87mm F23 block, crank, rods.
That would be the cheapest route.
race2live
Dec 8, 2010 05:49 AM
Vtec87pr
Jan 22, 2010 02:20 AM
h22_SOL
18
Sep 11, 2007 06:16 PM
noslocvc
Jun 30, 2005 07:28 AM
HotWheelz
11
Nov 28, 2003 11:52 AM
