f22b can i put a f23 crank in it and would i need custom rods
Old Jan 19, 2008 | 09:17 AM
low13da9's Avatar
Default f22b can i put a f23 crank in it and would i need custom rods
or what other cranks can i use to bump up displacement im going na and im going to use 15.1 compression pistons and i need help please
Old Jan 19, 2008 | 05:47 PM
street_accord94's Avatar
Default Re: f22b can i put a f23 crank in it and would i need custom rods (low13da9)
15:1 huh?
i would not recommend attempting to fit the f23 crank in an f22 block
Old Jan 19, 2008 | 10:57 PM
BlkChryKord's Avatar
I dont think it'll fit anyways. I think all the f22's had 50mm mains. F23 is 55.
You could use the crank from an H23 though.
Old Jan 20, 2008 | 08:23 AM
Default Re: (BlkChryKord)
correct on the different main diameters. however, the h23 crank is the same as the f22's.
PayMecracka
Sep 27, 2012 09:49 AM
rbeharry
May 15, 2009 09:28 PM
DMF
Mar 24, 2008 05:48 PM
DrivinVtec
Nov 30, 2006 02:13 PM
somboa
May 31, 2006 12:50 PM
